Problems with my week old C63S - transmission and headlamp??
After six months waiting for my Brilliant blue C63S sedan, equipped just how I wanted it, the car started showing issues after only a couple of days driving it.
Problem 1: "check front right sidemarker lamp"
This came up when I drove it into the garage and the message came on. I checked the lamp after I parked and it truly wasn't going on on the right side while the one on the left was working normally. After a few hours, I'd turn the car back on and it would be working fine, but it would at times be inoperable.
I took the car in, and they replaced a faulty front right headlamp module. They drop the car off, and as soon as I drive it into the garage, the same problem arises. I call my service advisor and he tells me to bring it in tomorrow so they can replace the entire headlamp. In the back of my mind I always knew that was probably going to have to happen to actually get it fixed.
Problem 2:
Yesterday, I drove my C63 to the dealership after it being dropped off to me because I had to get my C450 which was at the collision center fixing a small ding. As I parked the car, I was about to engage the transmission into reverse, and the car just shut off. It stalled as if it were a manual car. The car was in sport mode, and I had filled the gas tank 10-15 minutes prior because the car was about to run out of fuel. Since I was at the dealership, my salesperson got in the car with me and we drove around and did a couple things switching the gears between reverse and drive and he would observe the dips in the rpm and everything seemed normal. A friend of mine who has both a W204 and W205 C63, told me it was normal and it happened with both of his cars once. I was told not to worry by everyone, and when they replaced the headlamp module they also ran a multi-point inspection where nothing out of the usual came up. If there was something serious with the car, something would've came up there. This morning, 30 minutes ago, I'm driving into a parking garage and I pull into a space to the left which is right in the middle of a ramp. As I drove into the garage, I was getting the car from Sport+ mode into Individual (which is pretty much Sport with the exhaust valves on sport+) so it cycled through Sport and Comfort before I got to individual. As I did that the car was creeping forward and after I set it to individual I pulled the car in. Then, as I stopped the car, the car stalls again. It just shuts off. The instrument cluster's icons all went off and the gear said it was in Drive. Then I put my foot on the brake and powered the car back on and everything was fine. All the temperatures were in the correct and appropriate range, in both occasions. My friend with his C63 said that as this car has a multi-clutch transmission made to handle more power, I should be giving it more gas or else the car will shut off and stall. I'm used to just not even touching the gas when parking like I did with the C450 when it was my daily driver. It has never happened to me when waiting on a red light however. I drive it usually in sport mode aggressively (staying under 4500 rpm at most times to respect the break-in period) so I give it enough gas when driving, but not when parking. I really treat this car like a baby.
I'm extremely frustrated, the car has only 140 miles and it's presenting these issues. I'm treating the car like a baby and don't want anything to be seriously wrong with the car. I can try to get this car called a lemon and get a new one, but I don't want a new one. I waited 6 months for this exact build to come in. I don't want to wait another 6 months to get another car, nor do I want some black or grey or white that just blends in. I love my car, I don't want anything like this to happen to it. I was hoping you guys could give me some advice on what to do. I'm planning on getting this checked out tomorrow when they replace the headlamp. Thanks everyone
I have another type of transmission issue albeit really really minor (not even sure if it is a problem) but when I am coming out of the ECO stop, I step on the gas, the car won't move much almost like if I am in between gears or clutch slipping. I have to step the gas harder for it to start moving. This does not always happen. Just sometimes.
Yes, it happening two times isn't enough to call it a huge problem but I'm starting to think it might not be an isolated issue if it keeps happening. I am super upset with the fact that a brand new car like this has all these issues already. I'm going to bring it in tomorrow and see what's going on with it, I'm hoping for the best
There's a guy on YouTube that had a C450 and it was a lemon and they gave him a deal where they'd give him a new C63 as a replacement instead of another C450, I'll try to find him and ask how he made that happen but if they give me a new E63 as a replacement that's fine by me too
I just have never been in this situation before and I don't know what to do in the event that it is a lemon. I'm really hoping it isn't and that whatever is wrong gets fixed and then I have no problems from here on out though.
I would make sure the dealer documents all your concerns and just keep driving it for a few hundred miles.
I have had some warnings and unusual things happen mostly near start of my ownership and they never come back.
keep a log on these items and learn the idiosyncrasy of the car and especially the trans.
Never drive in C unless you grandmother is with you
S+ and loud and enjoy.
Brought it in this morning, they replaced the headlamp and not a problem with that. But as for the engine they were not able to find anything wrong with the car whatsoever. They thought it could be a fuel related problem which would make sense because the car started acting up around 15 minutes after I filled the gas tank at this sketchy Chevron gas station and my car was pretty much about to run out of gas (which is why I stopped at a shady Chevron which was the closest place to me). However if it was fuel related we'd be getting misfire error messages and what not. I was given a Mercedes Benz fuel additive and was instructed to drive my car until it's out of gas and then fill it up at a Mobil or Shell (places I usually go to and never have trouble) and add the fuel additive to the tank. If nothing else happens to the car after that, problem solved. If not, then we can rule out fuel related problems and move on with another hypothesis. My service advisor told me that we could possibly do a software update or reinstall which could most likely get this fixed, but he wants to hear the thoughts of the service manager who's very good with technical stuff of that sort and he'll be back Monday. I'm hoping that we can fix this from the fuel thing or the software update because I don't want to live with this headache for longer. What do you guys think? If you guys can ask your local service advisors about my situation I'd appreciate it, would love to see some second opinions maybe it could be of help.
remember keep it out of C as its not the place to BE.
And in Sport mode, it's pretty easy to keep it under 4500 rpm. Just don't mash the throttle and it'll behave itself. Only reason I don't drive it all the time in Comfort is because I like the throttle response of S and S+.
