C63/C63S AMG
Command system not working?
Old May 15, 2017 | 04:37 PM
milan25's Avatar
C63 s Edition 1 Sedan
Has this ever happened to you. I let the car sit for 40 minutes and then started it back up and no change!!!
Old May 15, 2017 | 04:42 PM
Gungaslow's Avatar
2017 C43 sedan
Hit the power button!!
Old May 15, 2017 | 04:50 PM
milan25's Avatar
Where is the power button?
Old May 15, 2017 | 05:12 PM
roy777's Avatar
2020 C63 Coupe
If you have PE, then the power button is the volume rocker on the center console. Click the wheel down. If you don't have the PE, the power button is right under/below the volume rocker in the center console.
That's from my experience at least.
Old May 15, 2017 | 05:13 PM
roy777's Avatar
2020 C63 Coupe
Right after I posted, I realize "volume rocker" isn't the correct name. Sorry, its more volume scroll wheel...
Old May 15, 2017 | 05:18 PM
milan25's Avatar
well dang, learn something new everyday. lol
Old May 15, 2017 | 05:19 PM
milan25's Avatar
Never new the volume dial was the power button
Old May 16, 2017 | 04:09 AM
SBH-'s Avatar
C63S 2016
buddy I had the same issue last year. I was told that sometimes the system while starting up will freeze if there is anything connected to the ports (USB, electric socket etc..).
My salesman told me to unplug everything from the ports and leave the car overnight or at least for 5 hours if I'm not mistaken for everything to reset. ( if you notice, the settings for the exhaust, engine, suspension etc .. will stay the same even after you turn off the engine for at least 4 hours. afterwards, everything resets and even the command system).
I did it, and next morning everything was perfect ! it was the first and last time I face this issue. hope it helps
