C63/C63S AMG
HRE Wheels | Mercedes-Benz C63S AMG with HRE P201 Wheels Installed
Old May 23, 2017 | 05:28 PM
HRE_Jurrian's Avatar
Former Vendor of MBWorld
Widebody V8
Mercedes-Benz C63S AMG with HRE P201 Wheels in Satin Charcoal!
20x9 / 21x10.5 on 255/30/20 and 295/25/21 tires
Thanks for taking a look!
Old May 23, 2017 | 10:44 PM
AV1's Avatar
AV1
C204 C250-CDI
Very Nice !
That's a much better HRE set up than the white W205 on the other thread
Old May 24, 2017 | 12:19 AM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Originally Posted by AV1
Very Nice !
Agreed, this looks great!
The other one is definitely a personal taste
Old Jul 17, 2019 | 08:09 PM
dbellard0912's Avatar
MB E350
Sidewall Height and Lowering Kit
Why is the sidewall height so low. 20 and 25 is very low. That will be a hard ride and may cause rim damage on some pot holes. Also, what lowering kit did you use.
Thanks for the info. I am looking at those wheels in chrome. Very nice style.
Old Jul 17, 2019 | 08:54 PM
superstarR's Avatar
AMG C63S
Very Nice !
The large wheels looks awesome, but make the brakes look small now.
Old Jul 17, 2019 | 10:28 PM
AV1's Avatar
AV1
C204 C250-CDI
The rear brake discs look small even with 19's
I'm in the market for several different rim set ups for this vehicle and that above even 2 years on is still best fitment for a 21" in the rear that I've seen.
HRE do some nice work.
Old Jul 18, 2019 | 02:04 AM
MB E350
Good to do research
I have been looking at wheels for a while and HRE are the best. I lot of wheels will fit but may not be made specifically for your vehicle. I have already chosen my wheels but I will not say, as I will have a one of a kine setup. The wheels will be HRE's for sure and Michelin Pilot Sport 4S. I will order the 2020 C63S convertible as soon as they are available to order. I will choose the European delivery as I live in Germany for 13 years and the Autobahn is so fantastic to see what your car can really do. Do not choose wheels for the looks but for functionality. Only buy a wheel that will have the German TUV, which means they have been tested on a German racetrack to be sure they will not make the vehicle unsafe. Many American wheel makers avoid the testing, as it can be expensive for them. Why spend so much money for a wheel and tire that will not allow you to drive 150p mph. or more. Also keep in mind that when you buy aftermarket wheels in a larger size, you will have to lower the vehicle to make if look great. Only choose KW Variant 3 suspension, as they are also German made to perform to a high German vehicle standard. They also have German TUV. A car with so much power must also be safe. That is the only way to feel safe putting the pedal to the metal. Good luck and ask many questions an do your research. HRE's are the only American brand wheel I would ever purchase.Avoid 3 piece wheels and tire shops will most often damage the inner seal and cause you many problems. Mono block forged aluminum are your best choice. Always purchase the tire hazard warranty as it will pay off in the long run. Discount Tire is the best place for tires. They are really flexible if you ever have a tire issue. Always get and keep your wheel alignment up to date. Once a year is normal. It will save on improper tire ware. I have a lovely wife, but my car has always been my girlfriend. She deserves the best also. LOL
Old Jul 18, 2019 | 08:16 AM
alexasa's Avatar
c
You're wrong here. So many people don't seem to understand how tire sizes work. the first number is section width and the second number is a percentage of the width.
Coupe OEM specs:
front 255/35 19 x 9j et 25
rear 285/30 20 x 10.5j et 57
HRE Specs:
front 255/30/20 20x9j (same diameter)
rear 295/25/21 21x10.5j (less than 1% increased diameter)
Old Jul 18, 2019 | 08:19 AM
hyperion667's Avatar
2012 CLS63
GO TO THE BANK!! GET THE MONEY!
Old Jul 18, 2019 | 09:20 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Mine with some HRE's :-)
Old Jul 18, 2019 | 09:40 AM
2012 CLS63
Is there enough space for the lug remover??
Old Jul 18, 2019 | 09:42 AM
alexasa's Avatar
c
those are lug caps
Old Jul 18, 2019 | 11:57 AM
MB E350
You are right. But percentage of the width simply relates to sidewall height. A 30 height is ok but 25 can be a problem. I had 305/25/20's before. Did you need a lowering kit? The space between the tire and fender looks pretty large.
Old Jul 18, 2019 | 01:25 PM
thewb's Avatar
SPONSOR
www.wheelsboutique.com
Why is the sidewall height so low. 30 and 25 is very low. That will be a hard ride and may cause rim damage on some pot holes. Also, what lowering kit did you use.
When you increase the wheel diameter you must also decrease the tire sidewall height accordingly to maintain the wheel/tire rolling diameter that the car came with. Generally speaking you want to stay with +/- 2% difference from the OEM wheel/tire rolling diameter. Since the car above used 20" front & 21" rear these lower profile tires had to be used. If you disregard this rule and you have wheels/tires that are too short or too tall it can risk putting the car into limp mode.
HRE's are certainly one of the best aftermarket wheel manufacturers in the world & we're proud to be able to say that we have been their largest dealer in the world for over 15 years straight. It would be great to work with the both of you on your sets. Who knows, maybe you guys even pair up and purchase at the same time so I can get you a package deal
Old Jul 18, 2019 | 07:32 PM
MB E350
Why have you never addressed my question about a lowering kit. Suspension modification.
Old Jul 19, 2019 | 11:31 AM
MB E350
Just like I thought. No answer to my question. Only uses this platform for selling products with no expertise in lowering kits to make the vehicle look right. Your car needs a lowering kit. You just may have put these wheels on a car to claim it is yours. OMG. The aftermarket wheel market is full of smoke and mirrors. This is a prime example of that. LOL. Don't try to fool people. Everyone who spends 10,000 dollars for a pair of HRE's are not dumb. Are these wheels TUV certified. Please address all the issues to appear professional or an expert. Still waiting for your answer.
Old Jul 19, 2019 | 11:34 AM
FLC63s's Avatar
Who are you directing this message too ?? if you are asking someone directly, then use the "@" and start typing their name, so that it will tag them as well.
And I just read thru the thread and I am even confused as to what your question still is ?? So maybe : Restate your question, so people can see what needs responding too... :-)
Old Jul 19, 2019 | 12:23 PM
2012 CLS63
Whoh man........you expect info to just find you? Asking if HRE wheels are TUV certified is just dumb! OF COURSE THEY ARE TUV CERTIFIED!!
Your attitude reminds me of why the word 'entitled' even has any meaning in todays day and age
Old Jul 19, 2019 | 12:58 PM
MB E350
LOL. I'm not so dumb. The factory was TUV certified in 2011. That does not mean all the wheels they make are TUV certified. Do you have new info on their latest TUV certification. OMG
Old Jul 19, 2019 | 01:10 PM
FLC63s's Avatar
Old Jul 19, 2019 | 01:17 PM
2012 CLS63
^wrong thread mate
Old Jul 19, 2019 | 01:28 PM
FLC63s's Avatar
^wrong thread mate
I was just admiring the "cat fight" - I probably should have used this one to explain it
Dont mind me.. I am just chilling.....
Old Jul 19, 2019 | 02:53 PM
2012 CLS63
Not really a cat fight per say.......just trying to help this seemingly entitled person to some assistance
Old Jul 19, 2019 | 03:36 PM
MB E350
OMG! LOL. You have been exposed. You equate our discussion to a cat fat. Only women have a cat fat. Real men don't care or would ever deal with a women that have cat fights. You are so weak. Men who can afford such wheels have a special real women in their lives. More smoke and mirrors. Find a different platform of real peop0le that want real information. I guess you wear skirts at night. LOL. Go somewhere else with your comics and not here for real MB lovers that research this site for real and true information. Perhaps I will send you a pair of panties. You may like that more. You really suck. Please readers. Never trust a person like this. So weak and soft and does not appreciate the fact they you really want something special in your ride. Not for other people, but for yourself. LOL. What a loser!!!
Old Jul 19, 2019 | 03:43 PM
FLC63s's Avatar
@dbellard0912 are you directing that towards me ??
