C63/C63S AMG
Distronic/Cruise Control Problem!!
Old Jun 8, 2017 | 05:39 PM
jkob5's Avatar
19 E63s
Originally Posted by NSAMG
I have had the CEL light on since having this issue. How do I remove it.
I turn it on and off a few times, lock / unlock a few times, eventually it will go away.
So everyone with this problem has a EC tune? I know of 5 now. Perhaps they can chime in?
Old Jun 15, 2017 | 11:45 AM
jkob5's Avatar
19 E63s
After a quick reflash, distronic is working great and car is as strong as ever.
Old Jun 15, 2017 | 02:49 PM
NSAMG's Avatar
AMG GTR
That's great news thanks
Old Jun 22, 2017 | 04:35 PM
milan25's Avatar
C63 s Edition 1 Sedan
Have you got the issue fixed, It is happening to me but I got a dyno tune from a good shop nearby.
Old Jun 22, 2017 | 04:36 PM
milan25's Avatar
Was it the same tune reflashed or was it changed, could you let men know
Old Jun 22, 2017 | 04:58 PM
jkob5's Avatar
19 E63s
Yes it is fixed, tested multiple times. It is the same tune from EC, just reflashed.
Old Jun 22, 2017 | 05:12 PM
  #32
milan25's Avatar
Do you think if my tuner just reflashes the ecu then it should just fix it?
Not Eurocharged btw
Old Jun 22, 2017 | 05:45 PM
  #33
jkob5's Avatar
19 E63s
Not Eurocharged btw
hard to say. Probably not. See if they know about this issue and if they can fix.
Old Jun 22, 2017 | 05:51 PM
  #34
milan25's Avatar
ok thanks though
Old Jun 23, 2017 | 08:05 AM
  #35
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
its from the tune, so they changed it and flashed the car with the same flash 100%
common issue from some tuners ( which is obviously some wrong stuff in the maps)
Old Jun 23, 2017 | 10:34 AM
  #36
JacobsT's Avatar
2016 S205 Estate
It has to do with callibration.
It also might happen when driving on just cruise control if you don't have distronic.
Drive the car, it generates the error. Remove it from the logs (tuner has to do this) and then it never happens again.
Old Jun 23, 2017 | 04:36 PM
  #37
jkob5's Avatar
19 E63s
source on this? Not doubting just curious.
Old Oct 10, 2018 | 04:43 PM
  #38
DWilk's Avatar
CLS63S
samething happened to me. They just re code the distronic and all was good? Theyre re coding mine now. Hope it works.
Old Oct 10, 2018 | 07:05 PM
  #39
DWilk's Avatar
CLS63S
more on this...master tech re coded the distronic software test drove it and works. Software issue glitch easily fixed. No the tune is not wiped out as they dont need to access the ECU just odb2 plug I believe. Car runs well.
Old Feb 26, 2020 | 08:31 PM
  #40
TheMechanic's Avatar
C63s AMG, c230k
Well...
So this also happens to me everytime I try and use cruise control. Has same error and all. However I have no tune, it’s a completely stock c63s. Took it to the dealership to have it fixed. They couldn’t find anything wrong nor an error/cel light in the memory. Drove off the lot, tried CC and happened again. Reason i took it in because I failed smog because I threw a cel ugh so I have no idea what to do
