Help Wanted: Turbo Lag After Trans. Update?
Can some of you please test the following scenario and let me know your results:
Driving @ 37mph/60kmh in 5th gear right at 1,500rpm on a flat road. Sport+ & manual mode. If I floor it boost takes a 3 count to kick in and I don't really start getting solid acceleration for about 4 seconds (i get up to 2,000rpm in about 4.5 seconds).
I really feel like even in a scenario at low rpm before I really never could floor it and leave my floor on the ground without getting pretty heavy acceleration. Power when the turbo kicks in still feels the same as before, just more lag. Let me know your thoughts. I mentioned this to the dealer and have yet to hear back from them. Not sure if I should take it back and see if they can re-tune something.
Thanks!
Thanks!
It does feel like more lag than before in lower gears and higher RPM as well. Obviously less lag but more noticeable than before.
Of COURSE you don't have any acceleration in 5th gear at 1500rpm... you're at a HUGE gearing disadvantage... I doubt turbo lag has anything to do with it. I bet if you look at your boost gauge (if we can even rely on that) it'll show at least 2/3 boost, indicating the turbos have no problem spooling... and the ECU is probably holding back at that RPM and load with the boost & fuel injection to avoid low RPM pre-ignition (= boom)
And if your boost gauge shows no boost at WOT, then you most certainly have a problem and should go to the dealership. No need for public inquiry if something is wrong or not... There clearly is! Good day, mate!
I never said this car has a ton of turbo lag. In fact I said before that it seemed like it had near instentanous power. It just doesn't feel that way now. Thanks for the help guys, gotta love the forum. It always amazes me how people love to be negative instead of just trying to help people.
I'll just go drive another C63 to compare myself.
Also, this thread should be closed at this point. It's gone completely off topic and I'll get my answers somewhere else.
End thread.
The turbos on this car are capable of spooling really quick. Mercedes actually made a mistake in my opinion on the turbos. They spool too soon and run out at higher rpms.
Boost will not be changed with a tcu update. The shift points would change. I can't think of any reason why the update would change anything in a single gear like that
