C63/C63S AMG
Brake Pad Change Out
Old Jul 7, 2017 | 10:42 PM
Edition1JPA's Avatar
C63 W205 Edition 1
Hey Guys,
Wonder if any of you guys have changed out your own brake pads and if so, what torque #'s did you use to tighten up all the bolts after you've removed the calliper... Pain in the a$$ btw.
I'm chewing through the stock pads pretty quick and have a set of Carbotech XP8's waiting to get mounted up before the next track day...
Any help would be much appreciated.
I also have the carbon ceramic brake package... so the callipers will be a bit different but I will take normal calliper torque specs as I'm sure they will be close.
Old Jul 10, 2017 | 02:58 PM
See63esS's Avatar
2019 Audi SQ5, 2011 Toyota Tacoma TRD 4wd, 2016 Ford Focus se Hatchback
Originally Posted by Edition1JPA
Hey Guys,
I have. You don't need to remove the calipers on the front. I just snugged everything down tight. Probably in the neighborhood of 80-100 ft/lbs
Old Jul 11, 2017 | 10:05 AM
longbow0404's Avatar
2019 E63s
+2 On above
____________
follow us on IG @Miami_Benz_club
