K-MAC Camber Kit - Front
I have mine setup like a common family sedan which suits me as I don't track the car.
Best thing once these are fitted you will you will have the ability to set it up then have it fine tuned to your liking.
Go to a reputable suspension shop, tell them what you want out of the alignment and the shop should have enough knowledge to advise you on best setup to suit you.
I suppose like everything it will be trial and error until you get it how you want.
My only pre requisite was tyre life.
Good luck.
Any reputable alignment / maintenance shop should have a basic bench press.
Only requires an open height of 10". Type of which Pep Boys sell
Kevin
Wheels deffinately are showing a reduction in camber and still no scrubbing issues.
New Alignment below:
Hey Mate! Here is my current spec after the install. Running 1.8 front camber and the rears are 1.5. I was requesting for the same spec like yours but they said it might rub the fenders. They told me to drive and break-in for few weeks . Then they will recheck the alignment again. Also, im a bit concern anout the front caster,am running 7.4 left and 7.7 right. You think it shud be higher like 9.3-10? Thanks
i really wish i would have done even more research than i did prior to KW HAS purchase. starting to feel like the "look" isn't worth it in the least.
and $500 for a bushing kit? sheesh!
To invest in the camber kit now ensures your going to get maximum life from your expensive tyres in the future.
Seem ok?
I have a 20mm drop with KW HAS which sit the guards just on top of my tyres and my camber is set to -1.5 front from memory.
My alignments are noted above in this thread.
Its all up to the tyre shop I suppose on what they think is best for the roads in your particular country.
Theres a lot of adjustment in these K-Mac kits so you could probable request them to adjust the negative Camber out a little more if that's what you want.
I fly back to Australia tomorrow night and I'm just hanging to go for a drive...I would of loved to had an AMG while in LA but just could get one.
While the replacement thrust arm bushes allow to re adjust Caster to compensate and they are mono ball 2 axis / self aligning without the OEM oil and air voids. Providing improved brake and steering response.
Also manufacture for the C63/S65 front upper arm replacement bushings – precisely adjustable (#503216-1K).
When used in conjunction with the lower arm bushings provide some serious adjustment (Pos. or Neg.). Especially track days dramatically reducing understeer in the pursuit of hitting those corner apexes every time and allowing to go deeper into the corners with improved traction and braking response. The lower arm bushes also increasing track width by 40mm (1 1/2”). Then can readjust the lower arms back to street setting.
To complete the package – Rear kit provides Camber adjustment (for the 1st time) and extra Toe to compensate - precisely adjusting importantly lower – not upper arms. Retaining therefore clearance top of tire to outer fender (and easy access to adjust) #502226K.
Along with uprated bush kit for the ‘6’ rear multi- link arms. Reduced rear and flex/twitch, improved traction especially when applying power to lane change / overtake (#502628K).
Will have to get that labour quote from Motson Turbos for the Rear Multi Link Arms Bushings I paid for.
That will be everything done then...
Thanks for your great support and I hope these guys keep supporting your business.
placebo, maybe.....but it really does feel different. would love to test such claim if i could.
going to put on my winter wheels soon and mostly be driving my truck this winter but going to likely pick up a set of these for next spring
