▄ Winn Autosports ▀▄ | RENNtech performance upgrades W205
RENNtech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s! Our experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
RENNtech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicles entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RENNtech performance software unleashes the true potential of your Mercedes.
With the proprietary RENNtech ECU Tuning the W205 - C 63 AMG gains up to +56 HP and +107 LB-FT, based on power numbers measured by RENNtech. Please note that the Mercedes M177 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RENNtech ECU Upgrade fot the W205 - C 63 AMG is 601 HP and 657 LB-FT.
RENNtech Sport Mufflers are made out of T-304 stainless steel (SS) and 100% hand crafted in the USA. This exhaust system is rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle.
Our mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure, increasing exhaust gas flow and cylinder scavenging. The RENNtech Sport Muffler System for the W205 - C 63 AMG Sedan comes with an integrated valve system and utilizes the electronic OEM actuators. The system comes with all the required hardware.
The RENNtech BOV | Blow-Off Valve Adapters are designed as a quick bolt-in solution which are intended to release excessive pressure in high boost occasions. While releasing the pressure, the RENNtech BOV adapters create the on turbo-charged engines well-known "blow-off" sound. CNC machined out of 6061-T6 aluminum, the RENNtech BOV adapters are anodized in black and laser-etched. Due to utilizing the OEM electronic diverter valves, the RENNtech BOV adapters will not trigger the Check-Engine light.
The full set comes with 2 BOV adapters, 4 o-rings, 6 stainless steel bolts and an allen-wrench. The BOV adapters work perfectly in combination with the RENNtech ECU Upgrade, due to the adjustments to the electronic OEM diverter valves.
R1 Performance Package for the W205 - C 63 AMG includes:
ECU Upgrade
Stainless Steel Sport Mufflers w/Electronic Valve System
Front Grille Badge | Limited Time Only
C 63 AMG S (W205 | M177 | 4.0L V8 BiTurbo) Stock Performance:
Rated by Mercedes-Benz: 503 HP @ 5,500-6,250 rpm; 516 LB-FT @ 1,750-4,500 rpm
Rated by RENNtech: 545 HP @ 6,150 RPM; 550 LB-FT @ 3,700-4,700 RPM
Mercedes M178 engine performance when measured, obtains higher power numbers than rated from factory.
C 63 AMG S (W205 | M177 | 4.0L V8 BiTurbo) Modified Performance:
611 HP @ 5,650 RPM; 672 LB-FT @ 4,250-4,800 RPM
Note:
Bolt-On Sport Mufflers System, no cutting or welding required. Utilizes electronic OEM actuators. Estimated installation time 30-60 min
No cutting or modification needed for BOV Adapter installation. Estimated installation time 30-60 min
RENNtech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz C-Class Sedan. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined C-Class exterior design language.
The spoiler is coated inside and out with an all new acrylic UV protection system.
A second layer of UV protectant clear coating is also applied using traditional spray methods, in order to create a smooth and high gloss finish.
This spoiler is designed to fit any W205 - C-Class Sedan model from 2015 and up.
RENNtech Carbon Fiber Decklid Spoiler. Designed in the U.S. Produced in Germany
Note:
No drilling or modifications to the trunk are necessary, installs with 3M double-sided automotive tape.
Available in gloss and matte finish
ECU unit: $2,995
Sport Muffler with/without valves: $3,880/$3,480
BOV: $360
Carbon Fiber Spoilers (Gloss&Matte): $1,680
Application:
205 C63 AMG
Ordering:
Payment Methods:
- Credit/Debit Cards (Visa, MasterCard, Discover, American Express)
- PayPal
- Bank Wire
- Bill Me Later
- AZ Orders will incur 7.8% sales tax
- All international orders (outside of US and Canada) require Bank Wire or PayPal
Shipping:
Most orders leave via FedEx, however we do use some private freight companies. The most efficient shipping method takes precedence. Expedited shipping is available by request.
Contact Information:
Phone: 480.699.8752
Email: justin@winnautosports.com
Website: www.winnautosports.com
Please feel free to contact me via PM, Email, or Phone if you have any questions.
