C63/C63S AMG
C63s sedan 2016 suspencion
Old Oct 4, 2017 | 01:00 PM
darwin329's Avatar
w205 c400 c63s
Hi guys i need a favor. Anyone here have a photo of c63s sedan exposing the front suspension (exposing the uppet strut) ? Am ordering camber kit. The merchant was asking for a photo without the wheels.. I dont have tools so if anyone can share so i dont have to brong the car to the shop..Thank you
Old Oct 4, 2017 | 02:52 PM
longbow0404's Avatar
2019 E63s
You don't need tools to see the upper bolts of the suspension. All you need is to open the hood and remove the plastic cover.
Now if you need to see the full coil spring and damper unit, then you will need to remove wheels and really get your camera up there as the brakes are on the way
Old Oct 5, 2017 | 12:25 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Do point out C63S is upper wishbone suspension not strut.
We therefore manufacture a precisely adjustable (single wrench) Camber and Caster adjuster kit replacing the 4 lower arm inner bushings.
Providing up to additional 3 degrees Negative or Positive Camber.
P/N 503316K $480.
NOTE: OEM there is only front and rear Toe adjustment.
For the rear we also manufacture similar kit providing precise Camber (and extra Toe to compensate for this new rear Camber facility).
P/N 502226K $480.
Another popular kit manufactured is uprated replacement bushings (12) for the ‘6’ multi link rear arms. Providing significant improvement to rear end stability, less twitch/flex, improved traction especially when applying power to lane change/overtake.
P/N 502628K $480.
DHL delivery $30 (front and rear kits $50). We accept PayPal, Visa or MasterCard.
C63s sedan 2016 suspencion-502216-cover.jpg Name:  502226 Cover.jpg
Size:  15.1 KB C63s sedan 2016 suspencion-merc-502826-k.jpg
Old Oct 5, 2017 | 07:40 PM
darwin329's Avatar
w205 c400 c63s
P/N 503316K $480.
P/N 502226K $480.
P/N 502628K $480.
Attachment 414264 Attachment 414265 Attachment 414266
I wiill PM you
Old Oct 31, 2017 | 02:33 AM
K-Mac's Avatar
SPONSOR
I wiill PM you
Hi
Any reputable alignment / maintenance shop should have a basic bench press.
Only requires an open height of 10". Type of which Pep Boys sell
Kevin
