C63s Tires
I decided to go with continental tires.
What I see right now S63 coup and E63s with continental tires so they are very high quality.
). They're noisier, last a lot less, actually lousy in cool weather, and downright dangerous below 50s, and less efficient in rain. They're only excel in dry grip when hot. And since the C63 is not really a sports car (it's a GT car), they make little sense IMO. If I end up buying it, and it came with summer tires, I'd replace them with the DWS06s asap. Hope this helps.As a side comment, in my case, even summer tires make no sense in my Cayman GTS. Took it for a last drive tihs year a few weekends ago, and since the twisties are in the mountains here, it's never hot. So can never drive it like it was meant to be due to lack of heat. That day I was sliding all over the place a little over 0.8G, where max summer tires are supposed to corner above 1.0G. I bet I could have cornered harder on A/S3s or DWS06s. If I keep it, will probably switch, since the road noise of summer tires is driving me crazy, and don't really see any benefit of having them, since I don't track my car. A track would be the only place where I'd need better tires than a DWS06. So there you have it. Having summer tires doesn't even mean you can drive the car faster in many cases
. I’m very please with the outcome and feel that aside from preference to summer vs all season, this size tire should be stock. The only thing i could rely on with the OEM tires is that they would lose traction in 1st-3rd gear. While using 500hp to blow the tires off is tons of fun, i’d rather put that power to the ground. Noise is honestly minimal like i said and grip is unparalleled. i haven’t had any issues with temperature (pittsburgh) affecting grip although it is unseasonably warm still (~50-60 degrees). car will be garaged when temps drop to freezing as i have another vehicle for winter use. Appearance wise, these tires fill up the gaps in the wheel well much better and look beefy. The sidewall doesn’t spill over the wheel like it would with a 295 or 305 (depending on the tire). IMO it looks perfect. 285 is the max width for the sedan wheels and the torque our cars put out warrants more tire on the ground.
. I’m very please with the outcome and feel that aside from preference to summer vs all season, this size tire should be stock. The only thing i could rely on with the OEM tires is that they would lose traction in 1st-3rd gear. While using 500hp to blow the tires off is tons of fun, i’d rather put that power to the ground. Noise is honestly minimal like i said and grip is unparalleled. i haven’t had any issues with temperature (pittsburgh) affecting grip although it is unseasonably warm still (~50-60 degrees). car will be garaged when temps drop to freezing as i have another vehicle for winter use. Appearance wise, these tires fill up the gaps in the wheel well much better and look beefy. The sidewall doesn’t spill over the wheel like it would with a 295 or 305 (depending on the tire). IMO it looks perfect. 285 is the max width for the sedan wheels and the torque our cars put out warrants more tire on the ground.Front: 255/35-19
Rear: 285/35-19
Widest tires possible for the factory wheels.
Can't wait!
