How Does The C63s Sedan Handle In Snowy Conditions
I might be interested in the C63s sedan but worry about driving it in the snow. This would be my daily driver so please share your experience.
Thanks,
ed
You're definitely not owning the road like you would with AWD, but it gets the job done. Sometimes, it takes a little bit of work to get the car going from a dead stop, but other than that, it's fine. I actually enjoy sliding the car around a in the snow. Makes the crappy weather more enjoyable.
Toronto's winter's are much more harsh than Vancouver, so I'm sure you'll be fine there.
I bet a lot of those stranded RWD cars have All-Season tires though. Since they are in Vancouver, they don't even bother getting snow tires until they get stuck!
The car can still look good with some nice winter wheels on!
True that...... Winter wheel/tire combo for Toronto.....
Rears are 255/35-19 (10mm narrower than stock).
Michelin doesn't make 265/35-19 for Michelin Pilot Alpin 4.
Also, the rears came off my M3, which had the same stock tire sizes. So that worked out nice.
A more square setup is OK for winter, so 10mm narrower in the back is fine.
Thanks for the info.
Anyway, long story short: it wasn't that bad! The roads were mostly "slick"; there wasn't much in the way of accumulation. But I was impressed how well the car handled it, even with the worst possible tire option (outside of maybe something in an R-rated tire). I actually didn't even see traction control engage once until just as I turned onto my street and went a little heavy on the throttle around the corner. That being said: DON'T DRIVE A RWD (or any) CAR IN THE WINTER ON SUMMER TIRES!
My car's tail kicked out from the car downshifting, that's how little grip there was!
FYI, my wheels in the picture above are hubcentric, so no rings required. That was important for me to make sure there was no vibration at high speed.
Struggling to find any decent 285-30-20 tires.
It’s been snowing here in Toronto, been super happy with the ride quality
Hope that helps....
Some 19" wheels don't even fit over the C63S's larger rotors. The first set of 19" winter wheels I bought had a drop lip that touched the rotors. Lucky the shop found out when they test fit so I could order different wheels.
That's the truth . My BC Forged 19" front wheels are almost touching the caliper .It's so close I had a tiny rock wedge in between once
I have noticed that there is a definite trend for Midwesterners and other flat-landers to comment on how easy it is to manage with rwd in the wintertime. You will get a completely different take when you ask the same question to folks that live closer to the mountains. Steep grades and excessively banked roads are always challenging with rwd even with good tires. So what I'm getting at is that terrain is probably the biggest consideration here.
