H&R lowering springs c63s
MindPatient (07-08-2023)
switched from KW-HAS to H&R and am absolutely happy with the results. no funny sounds (yet), sits a tad bit lower than how the KW's were set, and the ride quality is equally as good (less harsh than stock). i'm still able to traverse driveways at home and at work without issue. the k-mac front bushing kit i'm slowly becoming a believer in.
will try and post a pic of the car (before, kw, h&r) in a bit.
#32
#34
#36
Really happy with my H&Rs, the drop is perfect and no noise issues I had with the KW HAS.
I'd only recommend though if you're prepared to use something like the KMAC kit to get your camber correct otherwise it will be way out as mine was.
I don't think there's enough warming on how far out your car will be if you simply lower it.
amalgam (05-01-2018)
#45
Thats a bummer that u need a camber kit for only a .8 drop usually that's not enough to throw it so far off where just a alignment couldn't fix it. Did anyone try just a alignment after with out camber kit and have the specs to see how far off it still is.
#48
Would like to know too..
#49
Zeek1 (07-15-2018)
