C63/C63S AMG
need help installing RW carbon spoiler
Old Jan 6, 2018 | 08:11 PM
Luis Tellechea's Avatar
C63 amg
I got my RW carbon front spoiler today. the box had 3 pieces, 6 screws and that is it!
there are no instructions, there is no 2 sided tape and I have no clue how to install it.
has anyone installed one and have instructions or can guide me how to install?
thanks
Old Jan 6, 2018 | 10:20 PM
skim7x's Avatar
Mercedes-Benz E63s AMG
That's not uncommon for these aftermarket pieces. I've never seen/used RW Carbon before, but even Vorsteiner aftermarket parts didn't always fit 100% on my past vehicles -- that's why I always have professional body shops always install aftermarket parts because usually something has to be fabricated / drilled / adjusted to make these parts fit properly.
Bottom line -- I'd probably recommend you pay a professional body shop that has experience with CF and aftermarket parts to do the install. This is the case with even Ferrari aftermarket parts.
Old Jan 6, 2018 | 11:22 PM
C63 amg
I would have expected it to come with instructions and all parts required to install.
i hope it was an oversight on their part and they will send me the instructions and any missing hardware required to finish the install.
Old Jan 9, 2018 | 02:41 PM
Vassago's Avatar
2017 C63s Coupe
Sounds like the three pieces connect together and two screws per piece and you supply the 3M tape. I bought the AMG from splitter and it had tape and it was three pieces as well. I bought my own screws, I believe it was like 12 all under the bottom.
Old Jan 10, 2018 | 09:08 AM
C63 amg
i spoke with them and they recommended attaching more screws and not using 3m tape. kind a crappy to pay $800 and they don't even include all the screws they recommend to use....
Old Jan 10, 2018 | 12:49 PM
RW Carbon's Avatar
Former Vendor of MBWorld
Mercedes GT55 AMG
Should of been some screws inside the box. PM me we will send you some.
Old Jan 10, 2018 | 01:47 PM
C63 amg
I only had 6 screws in the box. when I called it was recommended to use at least 12 screws. if that is your recommendation you should include them in your box. Also you should have some type of instructions in your box.
