C63/C63S AMG
Tire advice
Old Jan 31, 2018 | 11:46 AM
UniversalGC's Avatar
Lexus GS 350 F-Sport
Tire advice
I have a 2017 C63 S and am approaching 10k miles. Unsurprisingly, my rear tires are in need of replacement, but the front tires are holding up pretty well. Does it make sense to only replace the rear tires now or should I just get four new ones? I don't want to end up affecting the quality of the ride and/or handling of the car. I also want to avoid ending up in no-man's land going forward where my tire tread never really matches from front to rear. Am I overthinking this?
Also, I live in SC where it typically only snows a couple of times a year. Is a summer tire my best bet?
Old Jan 31, 2018 | 09:16 PM
Strafe1's Avatar
2021 E63 S Sedan
I've replaced rears only on C63's before with no issues.
Old Feb 1, 2018 | 09:01 AM
msd3075's Avatar
'15 C63S
Just replaced my rear tires a few weeks ago. Got a nasty nail in the right rear that couldn't be fixed. Replaced both rears because I've never liked the idea of only replacing one tire (different circumference, newer fresh rubber, etc) but also because the old rear tires were almost down to the wear bars and needed to be replaced soon anyway. I have maybe 35-40% tread life left on the front and will get all 4 new tires when those wear out (I'm assuming the rears will have significant wear then too).
If you do get only rear tires, I'd at least advise you to get the same brand/model of tire that's on the front. Don't mix and match different tires, even if they are in the same performance class.
Old Feb 1, 2018 | 11:51 AM
K3v7n's Avatar
2019 GT 63
Go PS4S; you won't be disappointed.
