C63/C63S AMG
Car is down
Old Mar 1, 2018 | 09:00 PM
D-5's Avatar
D-5
2003 E55
Car is down
The car won't start. All kinds of error messages popping up on dash, including "Power Steering Malfunction" "Parking Brake Inoperative" ...etc. The doors won't even lock. Car is now being towed to the dealership.
Old Mar 2, 2018 | 12:08 PM
Chino075's Avatar
c63s
Sounds like a dead battery, as I've gotten those messages, especially if you try to manually release the parking brake. Did you try to at least jump start it?
Old Mar 3, 2018 | 03:01 PM
D-5's Avatar
D-5
2003 E55
No I did not jump the battery. I regularly charge the battery with my Ctek charger. The last time I fully charge the battery was a week ago. It would surprise me if the battery failed without any signs. The car was towed back to the dealer the same day however they don't have the time to look at my car yet. I was told that I need to wait a minimum of 2 days before they can look at it.
Update: The car sat at the dealer's lot for 2 days and they were able to start the car multiple times without any issues. They do not see any of the error messages on dash. The battery was good. My service advisor told me if there's any issues with the battery he would have replaced it under warranty for me. A test was performed and nothing can be found that's draining the battery. However, they have found various low voltage codes in multiple control units. Cleared fault codes and that's it I got the car back.
This car sat at an impound lot for a month. 2 weeks ago when I picked up the car it started right up. I drove the car for at least an hour before going back home. The same night I hooked it up to my Ctek charger through the poles under the hood and gave it a full charge which I regularly do with all of my cars to maintain/extend battery life. I don't know if this incident has anything to do with the car sitting for a longer period of time. It's the weirdest thing I've encountered and hope its a one time thing.
Old Mar 3, 2018 | 11:59 PM
Chino075's Avatar
c63s
Yes, low voltage is definitely battery. That's weird that it started up after leaving it for 2 days, if nothing else is plugged other than the ctek charger. Hopefully it's one time thing.
Old Jan 4, 2020 | 03:40 PM
Slugsy's Avatar
E63 AMG Estate
So would you know it! Cleaned my car today and got the ‘critical level’ warning both in the car and by message. I think that needs looking at. Admittedly I had a proper clean today, probably was at it for 2-3 hours but that shouldn’t happen.
Old Jan 4, 2020 | 08:15 PM
Tuxdude's Avatar
2019 AMG C63S
You sure you didn't leave the doors/windows open during the cleaning or any of the lights/displays in the car turned on? This usually prevents the car and the electronics from going into the full sleep mode and will drain the battery. From a fully charged battery, within few hours you will see Critical level battery warnings. I know this because I got this two times, one when Xpel was being applied and other time when it was at the service center of the dealership.
Just start the engine, drive around for 15-20 mins to see if the battery gets fully charged and then leave it overnight to confirm that the battery level holds up. If you still see leaks you might want to get it checked out by the dealership.
Old Feb 24, 2023 | 01:07 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
old thread , but had the battery changed over under official MB used car warranty today at the main dealers hopefully no more "Critical battery" error and might actually get to use stop start.
worth a call into the dealers if you keep getting the message.
Old Feb 24, 2023 | 09:27 PM
Jimmy_c63s's Avatar
Thanks for helping out and letting others know about this. Lazy OP never bothered posting an update so cheers.
By the way just saw your join date 2003. Christ you've been here for a long time 👍
Old Feb 27, 2023 | 07:32 AM
ColC's Avatar
C63S
Was going to say the same thing, dead or dying battery. I had all these messages when I picked up my crash damaged C63s and the first thing I did was replace the battery, and they all went away.
Old Mar 11, 2023 | 11:15 AM
Alps's Avatar
lol, yeah been around a while, I joined when I had my c36, then E55, then w212 e63, then back to another E55 and now the w213 E63s.
Old Dec 1, 2025 | 05:06 PM
V70cat's Avatar
535XIT, E63S
1
Old Dec 2, 2025 | 01:39 AM
japamg's Avatar
Final Edition C63s / RS3 Sportback
2
