C63/C63S AMG
Do we need to replace brake wear sensors?
Old Mar 27, 2018 | 09:46 PM
amg8's Avatar
MY17 C63s Sedan
Question Do we need to replace brake wear sensors?
When replacing brake pads, do we have to replace the brake wear sensors as well? Or can they be reused? If we need to replace them, anyone know where is a good place to purchase them at?
Old Mar 28, 2018 | 03:18 AM
AbuDhabi_C63s's Avatar
C63s
Yes, if brake pads replacement message appear but if you replace the brake pads before message appear you can use same sensors.
Old Mar 28, 2018 | 10:08 AM
KJ's Avatar
KJ
2020 GLE 53 AMG
For BMW, you could reset the sensors by plugging them in backwards and then re-using them again normally. Not sure for Mercedes though.
Not saying you should (since it's better safe than sorry for such a cheap part), but just sayin'.
Old Mar 28, 2018 | 10:29 AM
ItalianJoe1's Avatar
2003 CL 600
If they haven't been tripped, they are technically re-usable. I've also seen them crack when removing and set a false warning either immediately or in the near future. They are only a couple dollars, not worth taking the wheel back off to change them later IMO.
Rockauto.com has them for cheap.
Old Mar 29, 2018 | 04:33 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
$90k car...$8 sensor. Replace it
