Panamericana Grill Swap (pre 2019 models)
I just called MB of Austin and spoke to a parts guy there. His confidence level in his answers rated as a 2/10 so I’m hoping some of y’all can find some good info on whether or not this can be a straight swap. I like this new grille a lot and would love to do this swap if possible.
Cheers
From the PICTURES though, it looks doable purely from the front view of the '19 and '18. Might need a little bit of retrofitting, but any shop worth their salt could probably do it.
Either way, I appreciate the input fellas.
Yes, bumpers are different. But mostly the lower valance part for the intakes and exhaust/diffuser. Grill and up, and hood, haven't changed.
You can buy one now from this site:
https://www.aliexpress.com/item/Z-AR...17a4680fe9d3-8
and the distronic sensors.
Not quite the same either, design-wise the knock-off followed the AMG GT's version rather than the slightly different new one. And I have the distronic stuff that basically requires me swapping the star. I believe the grills that support the distronic setup are fundamentally different than the grills that don't (they can use the regular star or the illuminated one).
By removing the mesh grill and installing the horizontal fins, rocks or other debris on the highway hitting either or both of your intercoolers will leave you with a very expensive coolant leak, all for no reason.
