C63/C63S AMG
Coupe Wheels on Sedan/Estate
Old May 13, 2018 | 08:37 PM
dangreene's Avatar
S205 C63S
Hey all,
I have an S205 C63s estate and want to know I its possible and if there are any changes needed to fit the 19"/20" dished look coupe wheels on an estate (wagon)??
No one seems to do it except for Rokenr on instagram but im unsure if any changes were made to allow them to fit?
Wheels are on the car here:
Old May 14, 2018 | 02:43 AM
dangreene's Avatar
S205 C63S
After some homework, the only foreseeable problem is the rear wheel will sit 13mm closer to the suspension from the standard 19" cross spoke wheels.
Does anyone know how much room is under there?
Old May 15, 2018 | 03:38 AM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
They are the coupe wheels.
Old May 15, 2018 | 01:56 PM
crazy1eye's Avatar
2016 C63S, 2012 ML350
Sedan/estate front wheel, 8.5” et38
coupe front wheel, 9” et35
just the offset will shift the wheel 3mm out further + the wheel is 1/2” wider, 1/4” or 6.35mm a side wider...
The front wheel will be 9.35mm out further & 3.35mm closer to the suspension.
Sedan/estate rear wheel, 9.5” et56
coupe rear wheel, 10” et45
just the offset will shift the wheel 11mm out further + the wheel is 1/2” wider, 1/4” or 6.35mm a side wider...
The back wheel will be 17.35mm out further & 4.65mm further from the suspension.
now this is just the wheels, depending on tire size you may have to add some to account for tire buldge.
Old May 18, 2018 | 01:21 AM
Sanch's Avatar
Just to clarify Rokenr is using the coupe wheels on the wagon - Not sure if he has used spacers for clearance or not.
Old Aug 19, 2019 | 02:17 PM
fullhouse's Avatar
SLK55
Bit of a thread revival but looking at doing the same, did you do this or not
Old Aug 19, 2019 | 06:49 PM
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
I’ve been running the coupe 19”f/20”r cross spoke wheels on my sedan without issue for almost 9 months. Just have to watch tire width on rears due to fender clearance but will be fine up to 285mm tires.
Old Aug 19, 2019 | 07:36 PM
Tuxdude's Avatar
2019 AMG C63S
Is the 285mm on stock wheels or aftermarket? If aftermarket how wide and what was your offset which you found to be safe (to clear the fender)?
Old Feb 6, 2020 | 09:28 AM
tozfeekum's Avatar
19/20 Coupe wheels on a sedan
So they officially fit and don't rub even at full lock but I’m concerned the fronts stick out too much. What do you guys think?
Old Feb 6, 2020 | 02:00 PM
tobeit's Avatar
AMG C63s
I don't see any poke. The rear tire looks a little stretched though - are tires OEM spec?
Btw, what rear diffuser do you have? Looks nice or is that standard on the FL models?
Old Feb 6, 2020 | 05:52 PM
tozfeekum's Avatar
Tires are OEM. Standard FL diffuser
Old Feb 7, 2020 | 09:32 PM
jj33low's Avatar
C63S, Gallardo
Looks great!
Old Feb 7, 2020 | 10:10 PM
Jimmy_c63s's Avatar
That looks beautiful mate. That first picture is sweet.
Could you show us some more photos please? I'm really digging it.
Old Feb 8, 2020 | 11:55 AM
Tuxdude's Avatar
2019 AMG C63S
The wheels look great on the Sedan. However with the tire sticking out so much, would you start seeing more road debris, small rocks and other stuff thrown over the lower side of your doors and side skirts? Even with the stock setup, that's a common problem.
Old Feb 8, 2020 | 08:21 PM
tozfeekum's Avatar
Thanks man! heres a few more
Old Feb 8, 2020 | 10:10 PM
Jimmy_c63s's Avatar
Sh*t that's perfect. Those wheels suit your car so much especially with the dark tint. Looks tough as.
Do the wheels rub or cause issues at all?
Old Feb 9, 2020 | 02:17 PM
Benzrider17's Avatar
C43 c55 C63
Wow looks amazing come out perfect
Old Feb 9, 2020 | 06:34 PM
tozfeekum's Avatar
nope no rubbing. Concerned about rock chips due to the front tires sticking out. But so far it’s been fine
Old Feb 9, 2020 | 07:51 PM
C63S1's Avatar
C63S Edition 1
If you lowered the car the feel the wheels would sit better
Old Feb 10, 2020 | 02:51 PM
alexasa's Avatar
c
lower it.
and put a meatier rear tire on
Old Aug 31, 2020 | 01:23 PM
Jimmy_c63s's Avatar
How's your wheel setup coming along man? Any new pics? Really digging the look especially with the Coupe RXC wheels 👌
Old Aug 31, 2020 | 02:51 PM
1slick_c63amg's Avatar
C63 AMG
Looks great... really digging the look
Old Sep 1, 2020 | 09:39 AM
zipzap's Avatar
W205 C63s 2015
Looks awesome !
Would def get a set but everywhere I look only sells them new for between 5000-6000 Euros !
Old Sep 1, 2020 | 09:43 AM
Jimmy_c63s's Avatar
Originally Posted by zipzap
Looks awesome !
I agree. They're my all time favorite AMG wheels. The RXC wheels look tough. Pitty they crack and buckle easily if the tire pressure is under 33psi and driving on bad streets. I've repaired both fronts due to lowering my pressures excessively. Apart from that, hopefully the prices come down on them as I want another set.
Old Sep 19, 2020 | 08:04 AM
Kymbo's Avatar
2019 C63s Sedan
is your car lowered too, I ask because i'm about to put the Coupe 19/20's on my sedan and it is lowered with Eibach springs.
i want to keep the Coupe 255 front and 285 rear tyres, so really hoping they wiil fit?
