C63/C63S AMG
2019 C63 vs C63S Coupe
Old May 23, 2018 | 11:29 AM
esquesk's Avatar
2019 C63
Long time lurker, first time poster. I'm about to place an order when the book opens for a 2019 C63/C63S coupe and wanted to make sure that my analysis was spot on as I make my decision between a S vs a non-S.
Key Differences:
Electronic LSD no longer a difference in MY19
Dynamic Engine Mounts no longer a difference in MY19 according to R&T. However, this appears to be conflicting with DOG information so TBD.
503hp/516tq vs 469hp/479tq
Leather Standard in C63S
Composite and/or (ceramic) Breaking System on the C63S
Other Differences:
19"/20" wheels available on the S. Additionally, option price is $350 less on the S for the AMG Cross Spoke Wheels that I plan on ordering
Carbon Fiber Interior Trim - discount of $325 on the S compared to the non-S
C63S has a slightly different steering wheel that's available as a $500 option on the non-S
The major differentiation for me in prior MY's was that the S had the electronic LSD, however, given the following;
1) I don't like leather seats
2) I would love the brakes but can't justify the price difference for them
3) I plan on giving the car a tune later down the line, so power differences are negligible in the long term
4) Anticipated price difference (optioned how I'd like it) is about $7,000 / ~10%
I'm leaning toward the non-S. Hoping to get some validation and or counterpoints/thoughts from the group.
Am I missing something big in my analysis?
Old May 23, 2018 | 11:40 AM
FearlessFarris's Avatar
2014 CLA45; 2019 C63s
If all of that is accurate, I'd go for the C63 (non-S) and put the money you save toward tuning, new wheels, etc.
NYCSoiL's Avatar
2018 GT R; G82; M340
I'm in the same boat, probably gonna go with the non-s and just get it tuned
Old May 23, 2018 | 01:22 PM
Rubpau's Avatar
c63 Coupe, GLC63
Since you're going to tune it, i would just get the non-s. If you wanted to keep everything stock, c63s is a good choice.
Old May 23, 2018 | 01:49 PM
Fame Douglas's Avatar
2018 C63 Coupe
non-S front rotors are 1.2" smaller in diameter.
Old May 23, 2018 | 04:29 PM
RDOCA's Avatar
2016 C63S Sedan
Key Differences:
Other Differences:
this was posted before
C63S vs. C63:
- Front bumper A-Wing is painted black on the C63S (painted body color on the C63)
- Rear diffuser trim painted matte silver on the C63S (painted gloss black on C63)
- 19'' wheels are standard on C63S with optional staggered 19''/20'' (18'' wheels are standard on C63, with no option to upgrade to staggered 19''/20'')
- 503 HP/516 ft-lb torque standard with C63S (469 HP/479 ft-lb torque standard with C63)
- AMG electronic limited-slip differential standard on C63S (AMG mechanical limited-slip differential on C63)
- Dynamic engine mounts on C63S (not available with standard C63)
- Nappa leather interior with the C63S (C63 comes with MB-Tex/Dinamica interior)
- Natural grain black ash wood trim with IWC clock comes with the C63S (High-gloss black trim without IWC clock is standard on C63)
- AMG Performance Steering Wheel w/DINAMICA inserts and 12 o'clock marking standard on C63S (AMG Performance Steering Wheel in perforated Nappa leather without 12 o'clock marking on C63)
- 6-piston red brake calipers with black lettering, larger diameter 15'4'' floating composite rotors (grey brake calipers with white lettering, smaller 14.2'' standard rotors on C63)
- Optional Carbon Ceramic front brakes only available as an option with the C63S (not offered with C63)
- C63S gets standard silver/red seat belts and door panel inserts (C63 gets black seatbelts and door panel inserts with option to upgrade)
- AMG instrument cluster on C63S gets red bezel around gauges (C63 has no red bezel)
- An additional Race Mode is standard on C63S along with Race Start (not available on C63)
Old May 23, 2018 | 04:38 PM
esquesk's Avatar
2019 C63
C63S vs. C63:
- Front bumper A-Wing is painted black on the C63S (painted body color on the C63) - Difference removed with Night Package
- Rear diffuser trim painted matte silver on the C63S (painted gloss black on C63) - Difference removed with Night Package
- AMG electronic limited-slip differential standard on C63S (AMG mechanical limited-slip differential on C63) - difference removed in MY19
- Dynamic engine mounts on C63S (not available with standard C63) - Potentially removed in MY19
- Natural grain black ash wood trim with IWC clock comes with the C63S (High-gloss black trim without IWC clock is standard on C63) - Difference removed with Carbon Fiber Interior Option
- AMG instrument cluster on C63S gets red bezel around gauges (C63 has no red bezel) - This is likely gone with the digital instrument option?
- An additional Race Mode is standard on C63S along with Race Start (not available on C63) R&T says that all C63's will get all modes - not sure if that's legit
Yeah - I had seen that post but wanted to make sure I wasn't missing anything.
Seems to me as if they may have cannibalized their own product by removing a lot of the differentiation between the trims.
Old May 24, 2018 | 01:42 AM
juse's Avatar
c63 coupe
Dynamic Engine Mounts are not avaliable for C63 non S version in facelift model
Old May 24, 2018 | 09:30 AM
esquesk's Avatar
2019 C63
Yeah - that's the impression that I received from reading through the D.O.G., but didn't find it explicit. R&T had this quote in their article;
"Mechanically, the biggest change is to the transmission. Gone is the old, slightly clunky seven-speed auto, replaced by AMG's nine-speed unit. Instead of a traditional torque converter, the gearbox uses a wet clutch, which the company claims saves weight and optimizes response. The electronic limited-slip differential, which previously came only in S models, is now standard across the C63 lineup. Dynamic engine mounts are also now standard."
https://www.roadandtrack.com/new-car...-info-pricing/
Probably a safer assumption to presume that it's still a difference between S and non-S.
Old May 24, 2018 | 07:22 PM
2018 C63 Coupe
The C63 doesn't have race mode but it absolutely does have race start.
