C63/C63S AMG
Newbie Question: Dynamic Engine Mount/Electronic LSD
Old May 23, 2018 | 11:37 AM
FearlessFarris's Avatar
2014 CLA45; 2019 C63s
Forgive the newbie question--I'm a guy who loves cars, but I'm not a "car guy."
Can someone please explain what a "dynamic engine mount" is, and the advantages it provides over alternatives for day-to-day and performance driving?
Same question for an "electronic limited slip differential."
Old May 23, 2018 | 06:47 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
I could answer, but it's definitely easier to find the answer using a Google search.
The explanation won't be short.
Old May 23, 2018 | 08:21 PM
amalgam's Avatar
W213 E63
There was a good video on YouTube from Mercedes that explained that but I cannot for the life of me find it!
Old May 24, 2018 | 12:31 PM
Yeah, thanks. I'll google it. I thought maybe someone could give me the "in a nutshell" response. I'm not an engineer, so I don't need or want to get too technical.
But, in a nutshell, I'll google it.
Old May 24, 2018 | 12:58 PM
Chigs's Avatar
2018 C63S Sedan
Dynamic engine mounts vary the amount of engine vibes that reach the car. Wanna be isolated from the engine or feel that V8 rumble and shake?
An eLSD allows the rear tires to spin at different rates while turning. The inner tire has a shorter arc to cover than the outer. Allows for more controled cornering.
Old May 29, 2018 | 02:31 AM
M177ED1's Avatar
C63S EDITION 1
dynamic motor mounts are filled with type of hydraulic fluid, based in driving mode a current is passed through to eithe increase or decrease the viscosity therefore increasing or decreasing the stiffness of the mounts. Stiffer mounts better when in harsher driving conditions with lots of g force high speed turning(ie tracking). Supposedly they can even vary in stiffnes to assist in keeping the motor stable/level during turns.
tip don’t go over lots of bumps or any large pot holes with the car in S+ (which stiffens the suspension and motor mounts) you can blow/pop/tear the motor mounts causes a leak.
eLSD similar to all LSD as mentioned before the allow the back tires to spin at differnt speeds allowing you to turn (google how Does an lsd Work) old black and white video will show you the best.
The “e” means there is an electric mechanism involved in the LSD usually an extension of the esp/stability control.
Old May 30, 2022 | 08:51 AM
The2021amgc63s's Avatar
The 2021 AMG C63s Sedan
C63s dynamic engine mount
hey man I had a random c63s owner say to me he had to get his dynamic engine mount replaced because he drove most the of the times in Comfort Mode and advised me to drive mainly in Sports + if I wanted the mounts to last longer. Would u have an idea what he meant and how(if hes right)? I just believed driving in Comfort Mode would make them last longer
Old Jun 22, 2022 | 08:21 PM
cls5504matic's Avatar
C63 Vert
I can't comment on active engine mounts. I can say a differential allows wheels to spin at different speeds. The issue is when one wheel loses traction the differential will push all the power to the wheel without traction.
The mechanical limited slip I am almost sure would be a torsen differential in this application although there are other types available it would not make sense to use them in this situation. A torsen differential multiplies the power from a slipping side to a side with grip. It is instantaneous versus a viscous coupling differential which usually needs the fluid to get hot or become viscous to lock the differential to enable power delivery to a wheel with grip when there is one without it. The downside to a torsen is if there is absolutely no grip for one wheel a torsen cannot function. In these cars there is some vectoring with braking which allows some "grip" to multiply to a wheel with grip in those situations.
An eLSD has a motor which locks up the differential. These can often lock up completely up to a certain amount of torque. Another advantage to the eLSD is you can control the locking with computers. While eLSD are superior a torsen in this application with brake vectoring should be excellent too.
Old Jun 23, 2022 | 04:03 PM
reignz's Avatar
2017 GCV, 2019 JEEP TH-E
in curious about this too as in my GTR I’ve driven 10T km in sports +
