Trans temp high and 2nd coolant tank empty
I have a 15' 63's and my trans temp was running very high. Going 60mph not even going above 2k rpms and the temp was at 210. I usually don't even get to 210 unless I'm driving hard in s+. I checked under the hood and the coolant tank near the turbos was dry. so i bled it and filled it but does anyone know why it went empty?
c63 BS; lc500; F-pace SVR; Jaguar P8, c63 p31
You have leak that is a result from a damaged radiator. See details here:
https://mbworld.org/forums/c63-c63s-...ad-debris.html
Welcome to the unfortunate club. It's not a cheap repair either.
All four our are being redone to be more efficient, 5 times stronger and will support high hp applications.
These me will be a available to purchase once done.
Should be be available for purchase once finished.
This is a well known issue. The only fix is to put aftermarket metal mesh in front of the coolers, anything more substantial would block too much air flow. Tons of threads and pics and information on this forum about the subject.
What is the best material to use to protect the coolers? Does the front end have to come off to do this?
Since my $1600 expenditure (I got a little discount), I've been paying attention to what other radiators look like in other cars to determine whether I should be pissed off or just chalk it up to experience. From what I've seen over the past two weeks, the radiator design in these cars leaves the cooling jackets unnecessarily exposed. In most other vehicles I've looked at, the fins (the part in between the coolant filled jackets) protrude beyond the cooling jackets instead of being inset like they are on these radiators. That allows the fins to actually take the initial brunt of any object that might hit the radiator, thereby fending off some of the danger. Looking at the picture above, the cooling jackets are proud compared to the fins and will be the first thing contacted by debris. Thanks MB.
Being that our cars are built for performance lite weight materials are used which in turn probably are the strongest.
Below are some photo of my customers fabricated ARE Cooling Heat Exchangers on my C63S after two and a half years. (A few bugs but no dents or bent fins)
Also a photo of one of the factory AMG parts, big difference.
ARE Cooling Heat Exchanger after two and a half years
Factory AMG Heat Exchanger
ARE Cooling vs AMG
