Check Engine light after exhaust upgrades???
Diagnostic: TECHNICIAN NOTEPERFORMED SHORT TEST, FOUND CODES CURRENT FOR LEFT,RIGHT AND CENTER EXHAUST FLAPS, FOUND MANY STORED CODES THAT DID SET THE LIGHT ON AT ONE POINT FOR O2 SENSORS ISSUES, PERFORMED GUIDED TEST FOR CURRENT CODES OF EXHAUST FLAPS, FOUND NO ACTIVATIONS OF FLAPS WHEN SDS OPERATES THEM, ADVISE FURTHER TESTING AND DIAGNOSTICS NEEDED, ALSO FOUND EXHAUST FLAPS NOT INSTALLED IN PIPING OF NEW AFTERMARKET EXHAUST AND THEY ARE ALL ZIP TIED TO COMPONENTS OF THE VEHICLE UNDER CARRIAGE, NEED FURTHER DIAGNOSTIC TIME TO CHECK POWER SUPPLY, GROUNDS, AND COMAND WIRING FOR EXHAUST FLAPS, AS FAR AS O2 SENSORS, NOT SURE WHERE TO GO WITH THEM DUE TO AFTERMARKET EXHAUST BEING INSTALLED, RECOMMENDING TO INSTALL FACTORY PARTS BACK INTO THE VEHICLE AND RECHECK ALL OPERATIONS OF O2 SENSORS AND EXHAUST FLAP OPERATION. PURSUE FURTHER DIAGNOSIS - NOT WARRANTY -
according to weistec. They reviewed my tune and even plugged it into another car and said it’s doing exactly what it’s supposed to do? So how do I argue that it’s still not right! If they did install my Ecu into another vehicle and it ran perfectly. Would that mean that maybe I have a bad o2 sensor? Or like an earlier comment- bad spark plugs?
For the exhaust, how does the ipe work on vacuum? If it doesn't have valve actuators, you might want to use the AWE simulators for the factory valve actuator connectors to eliminate the exhaust codes.
Same units across the MB and Audi lines. You will need (3) of them if you replaced the entire PE exhaust, as (1) on h-pipe and (1) per muffler.
Pretty sure these are it, but just confirm that they are. It would be awesome if these are my solution. Thank you for the info.
ANOTHER question tho! With this Ecu tune from weistec and this software update available at the dealership that makes the c63s not as jerky in certain dynamic settings and also giving the car more pops, and louder exhaust note. Will that software update effect a tune?
