What tune do I have?
Just picked up my new to me 2017 c63 coupe with only 6k miles and I am having a blast with it. However, when I picked it up from VA they told me it would not pass VA emissions inspection as it was tuned. I am in NC and emissions are not required for the next 2 years. However, I am getting annoyed by it breaking lose in sport mode on the stock tires, apparently a common problem. Can anyone tell me how to determine what tune I have and the easiest/cheapest way to revert to stock if I choose to do so?
Thanks!
Thanks!
Also, more parts of your story don't make sense. If they already took it to Mercedes, then Mercedes already knows you have the tune.
And lastly, you would pass emissions if it were just a tune. You'd have to have cattless downpipes to fail an emissions test.
So if you want to take the car back to stock without knowing which tuner tuned your car and sending it back to them, is by buying a brand new ECU, then have the dealership code it to your car.
So that 1300 dollars is not for just the coding session. It probably includes the cost of a brand new ECU.
What happened was the tuner at the time bricked my ECU. So only option was to get a new one. Updating it did not fix it.
You can keep the other one for some fun experiments for later down the line if you ever decide to!
I have been calling different tuners, and so far only Renntech tracks by VIN. They told me that they were mailed the ECU in May 2018, but could not get into it and so sent it back to the customer. The customer had told them that another shop had also not been able to get into the ECU. All the other tuners go by name only, not VIN, so I cannot find out if they ever bench flashed it.
The plot thickens....
What the other guy said is true, something is wrong with this picture. Tune wouldn't make it fail emission, something else is fouled up. I would suggest take it to get some sort emission test done or better yet have a certified mb tech inspect the car and find what is wrong with it. Dealer may be lying (hard to believe?) or saying that because they don't know any better. Or as a way to tell you not to come back if the drivetrain fails after x days.
Many members on here run tune just fine, myself included.
The tune is over $1500 at a minimum, since if this is a real ecu tune, they have to do a lot of labor to get to the ecu, i paid a lot more than $1500 for sure. You might as well consider it a perk and keep it if you can figure out what's really wrong with it (smog or not)
welcome to the w205 c63 club btw, hope you stay
I did not see any posts related to this car on the forum, and as the previous owner traded in the car for a hellcat I am assuming they no longer frequent the boards.
