C63/C63S AMG
Question about Tire Pressure (Michelin PS4S 20'')
Old Oct 3, 2018 | 10:30 PM
Jinggyjin's Avatar
C63S
Recently got a set of Zito zf01 for my sedan, and I'm currently running 255/30/20 in the front and 275/30/20 in the back. The current tire pressures are about 34 psi all around when cold (35 - 36 psi after 1 hour of highway drive). Do I need to put more air in?
When I'm on stock 19'' rims, I was running 39 - 40 psi all around when cold. Not sure if I need more air for 20''
Thanks for your input!
Old Oct 3, 2018 | 11:27 PM
RDO247's Avatar
C63S
Can you put some pictures up?
Old Oct 3, 2018 | 11:39 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
I was told to run less with my 285/30/20's , I'm running 36 cold
Old Oct 4, 2018 | 12:25 AM
RDOCA's Avatar
2016 C63S Sedan
39/40 all around on stock tires is not correct.
Look at the label on the back of the gas door.
It is not rocket science guys.
Up to 155 MPH is 38 front and 33 rear.
When you get ready to put on new tires look closely at wear on old and see if you had the right pressure by seeing if wear is even across the tread.
Too much air it wears more in center and not enough more wear on both edges.
Bad balance or alignment will give other wear patterns.
This car has a lot of camber and you might see extreme wear on the very inside edge of both fronts.It is hard to catch unless you check on A lift as it is almost on sidewall.
What ever you do or if you change sizes they are not the same front to rear.
Old Oct 4, 2018 | 09:40 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Wow, 40 PSI you must be ice skating!!!!
32-34 is the sweet spot (cold)
Old Oct 5, 2018 | 08:58 AM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
I am running 36/31 with stock size PSS..
Will try 255/275 for Winter sestup with Conti TS860.
