Simple mods to make stock exhaust louder?
Has anyone done a resonator delete and did it make a difference?
I have done a resonator delete on my other car, it did wake it up however it also caused drone inside the cabin. Would the same apply here too? Open to other ideas as well but only looking for relatively small mods as Id like to stick to the stock exhaust. Thanks.
True. I could probably do a secondary cat and resonator delete and replace them with a straight pipe. Only thing I would be concerned about is drone inside the cabin
There's a whole thread on this if you do a quick search.
2nd-cat delete, there is no resonator, there is no drone.
untamedd (10-08-2018)
I have a 2017. Can you go from 100% open using the module to going stock and using the exhaust button inside without plugging/unplugging unit?
they seem to have two products listed on their website but from what I can tell theyre both essentially the same and doesnt matter which one I get?
One version plugs in from outside the car. The new version get plugged in from inside the truck. It's best to get the version that works from inside the trunk.
FYI. The ASR only works with the performance exhaust and not the stock exhaust.
