C63/C63S AMG
help c63s rear diffuser removal
Old Dec 22, 2018 | 05:17 PM
Sydb1's Avatar
C63s
hi guys apologies if this has been covered I have a mode carbon rear diffuser for my coupe which I'd like to fit myself . Please can anybody shed some light or point me to the right post . I've looked but only found the sedan equivalent. Any help appreciated ! Thanks
Old Dec 22, 2018 | 05:20 PM
ShakyTom's Avatar
C43 AMG Coupe
Is a bumper off job, at least that's how I did mine.
On the coupe, it's a pretty involved task. Remove trunk lining, remove taillights, remove bumper.
Once the bumper is off you need to remove some rivets and clips to get the diffuser comes off.
Old Dec 22, 2018 | 08:55 PM
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
Idk how different it is for the coupe but I was able to swap mine with the bumper on.
Old Dec 23, 2018 | 03:03 AM
Sydb1's Avatar
C63s
Thanks I've heard it can be done with the bumper on can anybody confirm ? Many thanks
Old Dec 23, 2018 | 05:10 AM
Alexpark911's Avatar
2015 C63 S EDITION 1/ 2015 BMW X5M
bumper off
Old Dec 23, 2018 | 08:32 AM
untamedd's Avatar
2019 AMG GT R
I had mine replaced at Eurocharged and they took the bumper off as well. Installation instructions on the manufacturers website ask to take the bumper off as well.
Old Dec 23, 2018 | 08:48 AM
gOt BoOsT's Avatar
Get under the car and see if the 4 rivots are visible and acessable to drill out. If so, drill them out. Then use a plastic trim removal tool (two of them makes it easiest) to separate the diffuser from the bumper (it’s held in with clips) working from one side of the diffuser to the other with the trim tools. It should pop right out with a bit of pressure, but before you install the carbon diffuser, I would highly recommend removing the exhaust tips and painting them satin black. Looks 1000% better than chrome with the carbon surrounding it. You need to drill the tabs on the diffuser at the original location of the 4 rivots and replace them with new ones. Good Luck!
Old Dec 23, 2018 | 12:46 PM
Sydb1's Avatar
C63s
That's great thanks ! Also thanks to all for the replies much appreciated
