C63/C63S AMG
High boost after cold start?
Old Feb 14, 2019 | 11:10 AM
msd3075's Avatar
'15 C63S
I've recently noticed something strange that happens with my car when I first drive off after a cold start. I've noticed that the boost gauge will climb up to about halfway even though I'm barely giving the engine any throttle. It'll do this until I come to the first stop, and then after that it'll function normally. It does this in C, S, S+, and Race. It happens whether I'm accelerating normal or barely touching the throttle (<15 mph driving through my neighborhood). I thought maybe the gauge was just acting wonky, but I can hear the turbo spooling as it builds boost and then the diverter valve release pressure when the boost goes down.
Anyone else experience this? Is it normal? My car is a '15 that is stock and has had the ECU update.
Old Feb 14, 2019 | 01:22 PM
tekfoc's Avatar
Veteran: Army
18 E63S
Vacuum hose is probably pinched at the waste gate actuator.
Take to dealer there's a campaign on it from Mercedes for 15 and 16 models
Old Feb 14, 2019 | 02:11 PM
msd3075's Avatar
'15 C63S
My understanding was vacuum hose issue causes a loss of boost and a noticeable lack of power. That's not what I'm experiencing. I'm experiencing boost when there shouldn't be any, and then it immediately goes back to normal and functions perfectly (no need for a restart). I've had no lose in power, no MIL lights, and no other issues once it stops doing it.
And I guess I should clarify what I mean by a "cold start". I'm not talking about the actual temperature as much as I'm talking about how long the car has sat between trips. It doesn't seem to matter the temperature of the engine. It'll do it when the engine oil is at 50F, and it'll do it when it's at 100F+. And at each of those temperatures it'll do it once and then stop.
Old Feb 14, 2019 | 04:25 PM
tekfoc's Avatar
Veteran: Army
18 E63S
It can go in ether direction and can be a combination of a bad boost actuator and bad vacuum hoses.
we can go back and forth on this or you can actually get it fixed Painlessly by taken it to the dealer.
Might also need a ECU update also.
plus there’s a campaign for replacement of all ignition coils
on 15- 16’s
good luck.
Old Feb 14, 2019 | 05:31 PM
msd3075's Avatar
'15 C63S
on 15- 16’s
good luck.
My ECU was just recently updated (a few months ago), and I was one of the first cars to have the ignition coils replaced under the recall. So neither of those should be the culprit.
Just got off the phone with the head mechanic at my dealer. Described the issue in detail to him, and he said every instance of kinked vacuum lines he's seen so far have resulted in low boost codes and significant loss in power. None have resulted in what I'm seeing. He said just to monitor it to see if it changes but that he highly doubts I'm experiencing the issue from the vacuum line TSB.
Old Feb 14, 2019 | 06:38 PM
tekfoc's Avatar
Veteran: Army
18 E63S
I would just take the car in let them physically check it .
Old Feb 14, 2019 | 07:34 PM
msd3075's Avatar
'15 C63S
Can't take it in for a week or two due to work schedule. Main reason I asked about it on here and only called the mechanic.
