C63/C63S AMG
Definitive "coupe wheels on a sedan" answer
Old Mar 29, 2019 | 02:16 PM
Izaak Jordan's Avatar
2016 C 63 S AMG
After reading through many threads and thoughts about the question of whether or not C63 AMG coupe wheels fit on a sedan, here is my stock 2016 C 63 AMG S sedan with stock 2016 C63 coupe wheels and tires.
fronts stick out a bit but do not rub
rears are tight but they fit
They fit fine. No issues at all. No rubbing so far driving on awful manhattan roads.
Old Mar 29, 2019 | 05:36 PM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
is it 19/20 combo? what tires and size are you using. Thanks
Old Mar 29, 2019 | 05:51 PM
2016 C 63 S AMG
It is the 19/20 combo.
Tires are the Michelin Pilot SS, same as the stock sizes on the coupe which is 285/30 in the back and 255/35 ini the front.
the fronts do stick out quite a bit more than stock but it doesn't rub or interact with the bodywork in the 20 or so miles i drove it.
I believe this is about as wide a tire as you can run in the back, the wheels could take a 300 but it would hit the inner liner
Old Mar 30, 2019 | 04:19 AM
RDO247's Avatar
C63S
I ran the coupe front on my sedan for awhile with a 263/35/19 PS4S.
Filled the front guards nicely without rubbing and had a vertical side wall apposed to a stretched tyre look.
Old Aug 6, 2019 | 12:34 PM
notabenex's Avatar
are you still running these wheels? thanks
