ECU Update has my car feeling lethargic
I took my car to the dealership to get some warranty work done the other day (doorhandle LEDs and interior rattles) and they decided to apply an ECU update on my car C2019020002. I'm in Canada if this matters.
My car feels different and I'm hoping it's just the ECU re-learning my driving habits, but wanted to know what the community thought.
Before, my throttle seemed responsive and accurate relative to my pedal position. Now, there's this dead spot or the car just doesn't seem to want to go from a stop, almost as if the engine is holding back power? This is me starting from a stop slower than most other drivers on the road in my city. If I give her, she goes, but at lower speeds, my car feels hesitant.
My car also seems to hiccup when shifting into 3rd gear mostly. My transmission used to seamlessly move between gears, but now, it almost feels like it cuts power for a millisecond and catches itself in the next gear, which also jerks the car. When this first happened, I literally thought my engine turned off for a split second before it jerked into the next gear. This seems to happen on and off, regardless of the weather conditions and at lower RPMs.
Sport+ Mode seems fine, but TBH I haven't really been on it that often.
Is this normal with reflashing/updating an ECU? The driving characteristics were perfect before the update.
Thank you,
If you're in Greater Toronto Area, then this guy can definitely solve the problem for you. The bodyshop is located in unit 6, 3rd Heritage Rd, Markham. He might be the only one in North America that knows how to fix problems like this regarding control units...
@srO_Michael_Orz
@srO_Michael_Orz
