Rear diffuser for 2019 coupe
Ive ordered parts now from mb uk but not received yet so still no part number detail. Parts are on back order. Will post part no’s once received.
looks excellent!! where did you buy or where did you find part numbers?
edit: i see you bought from cks performance. was everything bolt up? any modification needed? it said some modification may be needed on prefacelift models.
You mind sharing where you got the carbon rear diffuser from? I take it you had to also get the rear pipe surrounds separately?
Thanks in advance.
Thanks in advance.
Where are you from? I’m asking because as far as I know the guys from where I got it do not send into the US
https://www.kunzmann.de/shop/en/
I take it you have no issues with the quality and service etc?
Regarding the diffuser, when you order it you get all necessary parts, including the pipes.
Good luck!
The shop added 2 screws on either end just for that addtional support.
A couple of requests/questions:
- Can you list out all of the part numbers?
- Does the kit come with the blank hole fillers for the park distance sensors, if you don’t have that option on your car?
