C63/C63S AMG
JB4 is here!
Old May 14, 2019 | 04:58 PM
AMGMessiah's Avatar
2018 C63S AMG
For the money, I feel C63 S same dyno numbers as non-S model is worth it. The boost by gear control feature of the JB4 is what should be a main priority as opposed to amount of power and wheel torque added.
Old May 18, 2019 | 11:39 AM
Vader-C63sE1's Avatar
2017 C63s Edition 1 JB4
Update, yesterday I printed out the instructions! My goal is to install this weekend, then get my Service B, I am putting back in my stock paper filters so we can get a true bone stock dyno, then install the high flow filters re-run the MAP 0 to see gain, then run the maps up to and including race fuel levels. Then it’s time for some better rear tires, as my stock ones are on the wear bars at 8,500 miles. At a stoplight race I got beat by a stock C7 Stingray Vette because I could not find traction that is really frustrating.
Old May 18, 2019 | 11:51 AM
ezatnova's Avatar
2016 C63S
That will be great to get that data!
Yeah I hear you on the traction. Sunny and 75 here today and I can’t get grip until third gear, stock. And my tires are in good shape (also stock)
Old May 19, 2019 | 03:26 AM
It’s underway finally!
Old May 19, 2019 | 08:50 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Nice!
Old May 20, 2019 | 12:11 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Well ....??? They said it a 4 hrs job.
Old May 20, 2019 | 09:06 AM
  #32
AlexZTuned's Avatar
2017 Porsche 911 C4
It’s honestly more like a 1 hour job. I’ve installed and reinstalled my Dinan piggyback multiple times in less than an hour.
5 minutes to unplug the negative battery (2 min for me). 10 minutes to remove airboxes (5 min for me). 5 minutes to remove the 8 or so bolts to get slack in the front engine harness (2 min for me). And then the rest of the time is finagling with the plugs (only front two are difficult if you don’t know how to unclip them). Takes around 15-20 minutes depending on how difficult you find those two front plugs. Putting everything back together and buttoning up everything with zip-ties, mounting the Dinan module, is about 10-15 min.
The first time I really took my time going line by line with directions from multiple install guides, and it ended up taking me around 2.5 hrs.
Old May 20, 2019 | 10:40 AM
  #33
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
i am going to install jb4 next week, is there any new info or video of install? i have only manuál which i got with my order in christmas..
Old May 23, 2019 | 12:53 AM
  #34
Well it’s done, installed!
Took me over 6 hours, to install the JB4 and the BCM. I will say it was not easy, I have a lot of experience working on cars, and have previously installed a JB3 on my previous 335i. This was much harder as MBZ leaves not a mm of slack in ANY cable or loom. Most of your time is spent cutting ties, pulling clips to make more slack to get to the MAP sensors. The FPS are easy...cake! However all 4 MAPS are a *****, only 1 on my car was relatively easy compared to the rest. The BCM connection was also very hard, no room to get in there an get at the connector. I have slender and long finger and forearms and that hardly helped, if you have fat fingers and large forearms good luck with the BCM. I did spend a good amount of time maybe 45-60min on the button up, making sure everything was reconnected and put back in place and then zip tying and tiding everything the way I like it, nice and tight.
If I did it agin I would use a lift and air tools for the under car pans, mine are in storage
The app is easy to use and once I connected the neg batt terminal back up the car started right up and everything is working!
I have not driven it yet, will tomorrow. I put back in my stock paper filters so we can get a baseline dyno, then base + high flow filters, then start running the MAPS!
More to come next week
The good news is that the firewall penetration was one of the easiest of any car I have worked on so hooking up to the OBD2 port was super easy.
Old May 23, 2019 | 12:57 AM
  #35
Old May 23, 2019 | 01:01 AM
  #36
Old May 23, 2019 | 01:36 AM
  #37
Klinh's Avatar
Congrats on the installation. I hope you like it. I decided to go with Dinan and were scheduled for installation tomorrow but I canceled and wait until I come back from vacation on June 3. Thanks for doing the dyno to share it with us. I thought about doing the air filter mod too.
Old May 23, 2019 | 06:51 AM
  #38
ezatnova's Avatar
2016 C63S
First, thanks for the update and thank you for scheduling dyno time to finally give us all concrete info on baseline, filters, and now the JB4 maps. Really looking forward to that!
Second, couple of questions.
Why did this involve removing anything from the bottom of the car? Was this only because you did the BCM? I scanned through the install instructions PDF and really don’t remember anything about getting at the car from underneath and removing shields.
How come you went with a BCM (rest of your car is stock except for high flow filters, it sounds like?). Is your plan to get pure Map 1 and Map 2 pump gas dynos before anything else involving the BCM and ethanol/meth/race gas, etc? Hoping that’s the case so we can see pure plug and play JB4 benefit to the S.
While you’re being so generous with your analysis, would you also mind documenting what you think about the boost reduction by gear? Maybe like trying with the baseline of 0 and seeing how it helps or doesn’t help to go up to the values BMS recommends on their N54 page? Do you have stock tires?
Thanks again for the info. Sorry to hear it is such a headache to do. Miss the days of 15 minutes for the JB3 on the 335i
Old May 23, 2019 | 07:02 AM
  #39
notabenex's Avatar
Is there any updated installation manual? I have first version bought before christmas 2018, going to install next weekend. Thanks
Old May 23, 2019 | 07:05 AM
  #40
ezatnova's Avatar
2016 C63S
I think you posted the same question a few posts above. No new manual or video.
Old May 23, 2019 | 10:58 AM
  #41
The BCM is the new Boost Control Module, and the only way to get to it is from underneath, there is just not much room at all between the fan shroud and block, and it tucked in there tight.
Yes planning to go with Ethanol and or Race Gas, then Water/Meth when that kit is available, maybe upgraded turbos in a year or so.
Yes, just need to learn and understand how to play with the BRBG feature, stock tires but the rears are bald at 8K miles so going stickier and wider (305) probably Nittos
Old May 23, 2019 | 06:51 PM
  #42
BMS's Avatar
BMS
2018 C63 Sedan
Here's a little teaser of our meth kit setup. Our 2 gallon kit fits perfectly under the cowls, no need to run wires or lines in through the car.
This meth kit took about 30 minutes to install Will have some dyno numbers posted soon.
Old May 23, 2019 | 07:28 PM
  #43
I just got wood!!
PreOrder for me on the Intakes and meth kit
Old May 23, 2019 | 08:23 PM
  #44
mr747's Avatar
c63
NICE SETUP
Old May 23, 2019 | 08:25 PM
  #45
Klinh's Avatar
I like both mods. Look very clean setup
Old May 24, 2019 | 11:13 AM
  #46
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
Does your kit use a progressive controller? What blend and what size nozzles? Are you able to see post meth iats without additional sensors? Very interested!
Old May 24, 2019 | 12:08 PM
  #47
untamedd's Avatar
2019 AMG GT R
nice intakes. almost identical to ZAC. Seems like everyone making this style isnt ready to ship out. neither BMS nor ZAC. sigh
Old May 24, 2019 | 12:39 PM
  #48
ezatnova's Avatar
2016 C63S
Shame that none of them have a little place to swap the AMG engine plaque on to. not sure how feasible it is to remove and place it anyway. Still, they could have the correct sized flat spot with a "BMS Tuning" plaque there that could be removed if people wanted to try and swap on the OEM plaque.
Old May 24, 2019 | 12:41 PM
  #49
untamedd's Avatar
2019 AMG GT R
ZAC does. Pretty sure the picture I saw had the original plaque on it.
Old May 24, 2019 | 12:45 PM
  #50
ezatnova's Avatar
2016 C63S
Oh wow. Sorry, I was assuming they were basically identical between BMS and ZAC
