C63/C63S AMG
Lowering/camber kit
Old Apr 25, 2019 | 02:31 AM
Kirkebjerg's Avatar
C63 AMG Stationcar
Lowering/camber kit
Hi guys,
I am thinking of lowering my 2016 c63s coupe with a set of H&R 20mm lowering springs.
Can you post pictures of cars with these springs installed ?
Do I need a camber kit ? Normally I would just have the car aligned and camber/toe adjusted to minimise tyre wear but is this not sufficient on these cars ?
Christian :-)
Old Apr 25, 2019 | 09:23 AM
skim7x's Avatar
Mercedes-Benz E63s AMG
You'll definitely need camber kit for the front... Rears should be fine
Old Apr 25, 2019 | 10:28 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
I wouldn't bother .... I have the bushings and I'm not impressed . They are installed correct , had 4 alignments done trying to get rid of an issue caused by the bushings where it tends to turn in on its own when going through a long curve at highway speed and they creak . They sent me another set of bushings saying they are updated but means I have to fork out hundreds of dollars more to replace them . I'm actually considering going back to stock bushings and just deal with replacing tires sooner , I only put on maybe 4000 miles a year . I'm never thought we would be test beds for their product while they try to sort issues out at our cost
Old Apr 27, 2019 | 09:29 PM
RDO247's Avatar
C63S
I’d fit both front and rear K-Mac kits as you will wear your tyres prematurely even at standard height.
I’ve been running these kits for approximately 18 months with no issues at all.
I think the issues maybe due to the install of these kits...Kevin at K-Mac gave instruction to my race shop and that was it.
Weird that I was probably one of the first to fit these and honestly forgot they’re even in the car.
Old Apr 29, 2019 | 12:09 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Get the K-Mac bushings, you will need them on a lowered car especially the fronts. My shop was able to get the fronts within factory specs with the bushings installed, and my car rides and handles much better. Also **** replacing tires every 3K miles that's just moronic even if you have money to blow.
