C63/C63S AMG
Pure 900 turbos problems
Old Sep 19, 2019 | 02:53 PM
koifysh's Avatar
2007 E350
deleted
Old Sep 19, 2019 | 04:36 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Originally Posted by ///Bruce
Get rid of those *****ty clamps man! They leak! Take it back to the SAME shop where the work was done.
With all due respect, those are OEM style clamps and are actually one of the best. We use the Oetiker clamps on our fuel systems that I build.
From what it looks like, the clamp might still have room to tighten.
OP,
You can get the tool from any hardware store, and try to re-tighten. If that doesn't help, you can use worm clamps and redo them.
-Payam
Old Sep 19, 2019 | 05:01 PM
TexasEd's Avatar
2019 AMG C63s Coupe
Get rid of those *****ty clamps man! They leak! Take it back to the SAME shop where the work was done. If you jump shops and something goes really wrong, who you gonna try to blame? Don't do that. If you can't go back, find a reputable shop and have them change the clamps out and inspect all the work YOU got charged for. "Inspect what you expect". Tell me... you can "see" what was done wrong, correct 9 (the pics)? Any chance there might be some shoddy work somewhere else that you can't see? Are all those bolts/nuts that you can't see torqued correctly? Everything else replaced properly. Hummmm.....
I'm not trying to be mean. Truly, I'm not. Go back and make them make it right. It's your car and your money. Get 'er done.
I agree, those clamps are crappy. If it were my car I would save myself further grief with the dealer and fix it myself. It's not brain surgery. Simply remove those clamps and install worm gear hose clamps from the auto parts store.
Old Sep 20, 2019 | 02:14 AM
zipzap's Avatar
W205 C63s 2015
Clamps
I’ve changed a couple of set of these turbos and I never had to take off any off the cooling line clamps, everything (both oil and coolant) have o ring seals so are easily removable. I’m not sure what they were trying to achieve by separating the line at this point
Old Apr 25, 2022 | 07:21 AM
anwar_hamoude's Avatar
2016 C63 AMG
2016 C63 AMG W205 with currently 36,000 miles.
I am considered installing Pure 900 Turbos. The problems I seen are installation related. Speaking on the reliability of the Pure 900 Turbos, is the reliability good?
I am not looking for a maximum power tune, I just want to run on pump gas (tuned for 91), no meth injection and keep the stock exhaust (DP).
I want the car to be reliable for daily use but with some more kick, just because. Is it realistic to think that after installing the Pure 900 Turbos I'd still have a reliable car?
Old Apr 25, 2022 | 10:05 AM
koifysh's Avatar
2007 E350
100% will be reliable with pure 900 turbos in my experience. Had them since 20k & now im at 60k miles. Multiple 2k miles road trips of hard driving. The most important thing is maintenance and upgrading your heat exchanger. I change oil and filter every 5k miles. Spark plugs every 5k miles, I use ngk one step colder plugs. Coils every 10k miles. Coolant flush once a year before summer.
Old Apr 25, 2022 | 03:09 PM
  #32
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Originally Posted by koifysh
I Spark plugs every 5k miles, I use ngk one step colder plugs. Coils every 10k miles. Coolant flush once a year before summer.
That’s crazy !!! For people the daily drive their car, it like spending extra $3k per year.
Old Apr 25, 2022 | 05:40 PM
  #33
2016 C63 AMG
I hadn't thought about upgrading the heat exchanger.
I spent $700 on new coils from MB Star Parts.
NGK Iridium plugs are $150 from NAPA.
One step colder plugs from NGK don't exist. Except for racing plugs. Stock plugs are heat index 8, one step colder would be a 9.
NGK 93253 R2556G-9 Racing Plug
I inquired regarding the use of this plug in M177 but didn't receive a positive response.
HKS has a NGK heat index 9 spark plug for GTR, which apparently fits M177. That is second hand information, give a try on google and see what you find, I have no experience with HKS myself.
Hearing one step colder plugs from NGK sets off my B.S. detector.
Old Apr 25, 2022 | 11:08 PM
  #34
koifysh's Avatar
2007 E350
corrections I meant to type in hks gtr plug not ngk. I’m currently using the one step colder gtr hks. Power delivery with these seems much more smoother. Stock plugs are perfectly fine eith just an ecu tune but for pure 900 and up. One step colder hks is a must.
Old May 1, 2022 | 12:09 AM
  #35
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
For the upgraded heat exchanger, what unit did you go with?
Old May 1, 2022 | 01:21 AM
  #36
2016 C63 AMG
After new turbo installation does the car automatically prime the turbos?
I am interested to know if there are extra steps to prime the turbos. Unplugging a fuse and turning the key isn't an option.
Old May 1, 2022 | 02:39 PM
  #37
MaxVO2's Avatar
2018 C63s
*****Generally speaking, no. However, to keep from doing a dry start on brand new turbos it is *always* a good idea to use a product such as Pro-Line Turbocharger additive by Liqui Moly. You will need TWO tubes, one for each turbocharger. It is squirted into the oil filler holes until the tube is empty, once the turbos are mounted but before the oil line is reconnected. The initial start up on new turbos is very critical to the longevity of the turbos and anything that can be done to prevent excess friction until oil starts flowing into them will *greatly* extend their potential lifespan. Don't be cheap and just squirt some oil in the holes - use the additive as it sticks better and lasts until it is washed away by fresh oil coming through after startup.
Also, it is *never* a bad idea to change out the oil in the car to fresh oil after the initial break in on the car with new turbos. A high performance motor is put under a LOT more stress than a mom and pop sedan driving the kids to swim practice, before band camp, etc..
Pic below of the product I like to use. It's good stuff. Good luck.
Old May 1, 2022 | 05:01 PM
  #38
2016 C63 AMG
Originally Posted by MaxVO2
Thanks!
I'll definitely use Liqui Moly Turbo Additive.
