Annoying buzzing sound from dash
My 2019 cab has now delivered a new noise. Under acceleration in a higher gear (generally in comfort mode) I get an annoying vibration, like a buzzing sound. Sounds like it’s right in front of me (right hand drive) but can’t pinpoint it.
Anyone else experienced similar?
Not sure. I managed to locate the one on the passenger side dashboard top. If I press down on the air vent adjacent to the windscreen it stops. Not sure what the permanent solution to that one is. This one is more of a buzzing than a rattling. Be nice to find the cause. Just when I accelerate.
My glove box was rattling for a while and i though it was the dashboard. I applied a small piece of foam inside the glove box right where the glove box meets the dashboard and the noise seems to have been fixed. Will say that the the plastic cowling around the dials also buzz from time to time.
the buzzing is so annoying as it only happens when accelerating lightly it sounds like ji ji ji ji but it's literally a buzzing noise 🤬🤬🤬
700HP Facelift converted PFL C63 S Coupe
I hear it with all windows up and no radio on
Accelerate gently or driving over long rough surfaces and it makes the sound "GRRIIIIIII GRRIII" sounds sort of plastic buzzing
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Sorry to hear about that, do you mind sharing us or give us a run down of what issues you experience and on a side note, how is your M3 : ) Hope you are enjoying it
Haha I've got the same thing in my coupe. Yes the sound is a BUZZING noise which I am sure it's coming from one of these areas.
Definitely a buzzing noise which happens if you accelerate gently. Even more apparent when performance exhaust is in ON (red button lit) and all windows are up.
Where abouts do you press for it to stop?
I'm determined to fix it. Might try record a video of it tomorrow and post it so we know exactly if it's the same sound.
Honestly mines not that bad though, only notice at highway speeds sometimes and that's if I listen for it without music on. Sometimes it's there sometimes it's not.
Still annoying now that I know it's there.
I just push on the speaker and surrounding areas, for the aircon I just grab the vent itself and squeeze/push. Pretty much just push and squeeze those areas.
Solved
Issue fixed. It was the flimsy little chrome trim that goes around the gear selector stalk.
Jammed some felt into it with my fingernail and NO MORE BUZZING.
If you're getting this buzzing noise on light acceleration and windows are up, tap on the stalk when the car is parked and you'll hear it buzz.
Hope it helps someone.
Another area for me to see if it's also part of the rattling/buzzing sound.
On another note, has anyone had any of their windows particularly driver side not closing automatically when you pull the button? Has happened twice but fixed itself after I restart the car on both occasions.
Glad you found your source of the issue.
Also my coupe driver's side window glass will rattle when driving if it's open just a tiny bit at a certain level. But roll it down further and the glass doesn't rattle.
So many niggly issues with these cars huh 🙄
yea agreed, every time i fix an issue a new rattle comes up somewhere. Its incredible how poorly built this generation of the c63s is, especially the sedan...my glovebox now creaks everytime i come to a stop or the engine start/stop turns off and turns on the engine...
Yeah that's happened to me once or twice and I thought here we go the regulator is playing up. Never happened again.
Sometimes it gets to the point where if I hear a random sound, might just be house keys in the cup holder I think f*** me another new rattle.
This car drives me insane man and the amount of repairing/maintaining I've had to do to this thing since new is ridiculous.
Try and see if it's your gear selection stalk that rattles. Tap it fast with your finger and see if it buzzes.
arm yourself with black felt tape just in case and use it if needed in the spots that rattle..... but u should be ok if removing whole glove box one weekend and assemble it again
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
mate same with mine....... had to take my glove box apart and assemble it again to fix it
Found it !
