Driving in the rain
The issue is that the torque comes on _so_ fast that one has to learn to always slowly "squeeze on" the throttle, when driving in the rain (or around curves, or when RPM is above 2500 RPM, or ... OK, so the saying _is_ true, "a C63/S always wants to kill you!). $;-)
Anyway the car did great on Mich SS tires. I actually got bored and threw it into S+ mode and a few times felt her break loose but it wasn't anything you could not control. I also owned a Hellcat for a while so I know all about losing traction and how to handle it...LOL
I bought the car CPO and the dealer put these tires on it before I bought it.
Tires are PS4S, less than 5,000 miles. Alignment is correct. Granted, when I went sideways, both times it was in comfort mode, while using adaptive cruise control (long highway drive to and from work). But even that aside, the rear end definitely doesn't seem as planted as other cars I own/have driven in the heavy rain. Maybe its the weight vs the downforce of the other vehicles?
Wondering if I'm the only one who feels this way about the C63S being not too confidence inspiring in heavy rain? (By comparison, I can do 90+ mph in heavy downpour on high performance tires in other vehicles that are either much heavier or have rear spoilers, and the vehicle feels much more planted).
ps4s can be twitchy in rain depending on tire pressure
if it wasn't for their good dry grip I'd go back to super sports
just don't turn off the traction in the rain or you'll end up like this fella
By comparison, Cup 2 MO tires are terrible, yielding only about 0.6G lateral grip (C63 S and GTR) before sliding on wet tracks ... but, of course, their dry performance significantly outperforms the PS4S.
If you want more rear traction on a C63 S, you can use an old winter-driving "trick" ... add extra weight to the rear. In my C63 S, I added about 60 lb of weight to the rear by filling zip-lock bags with play-sand from a hardware store to create 3 lb and 5 lb weights and stuffing them down underneath (as low as possible) in various voids under the trunk area. While the extra weight is a disadvantage for some aspects of handling, the increased traction on a track having many slow/sharp corners got me better lap times. Since I often purchase fuel across the border, I did always worry about being selected to participate in one of the random vehicle searches ... "no, no, those baggies are not drugs ... just play-sand for weight" trying to avoid being slammed against the wall and told to "spread 'em." #;-)
Checking the app right now (been at work all day so tires are cold), LF 35, RF 36, LR 34 RR 34. I'll bring them down to 33F and 32R and try that. I have 19/20" OEM staggered setup FYI.
It really sucks feeling so unconfident in the car's traction when it rains...and FL is notorious for sudden heavy downpours...
Yeah, not really sure what to tell you assuming your tire pressures are good. Now if you have standing water and puddles where you drive, then you are likely aquaplaning which all comes down to the tires. The one thing to know is that wider tires aquaplane much quicker than skinnier tires. The only car I ever aquaplaned with was my 2013 RS5, which had 275 shoes on the front and one day they started to float after a heavy downpour. The tires were Pirelli P Zero (not the best in the wet) and somewhat worn, so it was the perfect storm. Luckily I was going mostly straight and after letting off the throttle they regained traction. The rear tires on the coupe are fat and they handle all the propulsion, so a bit too much throttle and there may not be enough lateral grip left in the wet, or they simply reach their limit of how much water they can evacuate in heavy rain.
