2019 C63 secondary cat delete
I’m looking into getting my secondary cats deleted on my 2019 C63S sedan. Does anyone have any pictures of the location of the secondary cats?
From what I gathered, they should be at the end of the downpipes. A mechanic that I went to was expecting it on the mid pipe so he said the ones at the end of the downpipes were the primary cats but I think he was mistaking it for the W204 setup.
Based on these two pictures, I think both the primary and secondary cats are located on the downpipes. The first picture was posted by another user and shows the full stock catback portion of the exhuast. No secondary cats or resonator to be seen
Now, from westec's website. Their catless downpipes next to stock downpipes. Notice there appear to be cats at both ends, the primaries located almost right behind the turbos and the secondaries are probably what your mechanic is seeing closer to the bottom of the downpipes.
This is a much different design from the w204 which had primaries where you'd expect them followed by a set of secondaries where our h valve sits and then a big resonator in the middle. deleting either of those or both could get you different types of sound all louder than stock. I figure this is an NA vs FI design choice. Either way, if those secondaries on the downpipes don't have a sensor after them it is probably completely safe to delete them.
