C63/C63S AMG
Daily Driving Modes
Old Jan 14, 2020 | 10:08 AM
PayKoHan's Avatar
AMG C63S T-Model
Yes, 2016 is pre-FL. 2019+ is FL. Yes, for the German Autobahn, S or S+ would be best, IMO. You want ESP to be fully on in case something happens at those high speeds. Best chance to come out in one piece. When I did my European Grand Tour with my 2019 I actually used I*. Had it setup with engine in S and suspension in Comfort, along with AMG DYNAMICS in Pro and exhaust open. S+ in the 2019 was a bit jolty when upshifting under full throttle and a bit detrimental to traveling comfort at high speeds, so S was a good middle ground. Depending on how fast I was driving and the road conditions I would then ratchet the suspension setting up and down. Closer to the top speed I would put the suspension in S+, but if the road got a bit rough I would take it down to S or C. Back home in the USA, I'm still using I* for highway driving and spirited driving, but I changed the engine mapping to S+.
ok thanks.
and which modus is the best for performance (100-200kmh) for best time?
sport+ and esp off? Manual?
Old Jan 14, 2020 | 10:12 AM
superswiss's Avatar
2019 C63CS
Originally Posted by PayKoHan
ok thanks.
There's no difference in power between the modes, so acceleration will only be affected by other factors such as traction etc. Shift times are different in the various modes, so in Comfort it would be slightly slower than in Race, but doubt you'll notice that unless you time yourself. If traction is limited, than traction control can actually make the car faster, so turning off ESP may be counterproductive. The pre-FL has the fastest shift times in manual mode, and it actually tweaks ESP as far as I remember. The head of AMG commented about that a while back, so the manual mode was kinda special. I don't think that's the case anymore in the 2019+, because the 9 speed MCT is overall a lot faster than the old transmission and the whole ESP in conjunction with AMG DYNAMICS as very different and on top of that the 2019 C63S has the 9-stage traction control from the AMG GT R.
Old Jan 14, 2020 | 03:26 PM
8cd03gro's Avatar
17 C63S Coupe
I see people saying they put the drivetrain in race for their individual setting. Is that a FL-only option? I only see C, S, and S+ as options for the drivetrain in I.
Old Jan 14, 2020 | 03:31 PM
Encore818's Avatar
2019 C63S Coupe, 2020 G550
Yes. FL has a race mode in addition to Comfort, Sport, Sport +, Individual and Slippery. And for Individual you can set the engine to be in Race.
Old Jan 14, 2020 | 09:21 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Pre FL also has Race mode.
Old Jan 14, 2020 | 09:25 PM
Encore818's Avatar
Didn’t know that.
Race can’t be used in Individual though?
Old Jan 14, 2020 | 09:27 PM
  #32
untamedd's Avatar
2019 AMG GT R
Originally Posted by Encore818
Didn’t know that.
it can
Old Jan 14, 2020 | 09:30 PM
  #33
PayKoHan's Avatar
AMG C63S T-Model
Yes, i have race modus.
S got race modus non S dont have race modus.
Old Jan 14, 2020 | 10:33 PM
  #34
8cd03gro's Avatar
17 C63S Coupe
Originally Posted by untamedd
it can
How? The drivetrain selector for the individual settings only has C, S, and S+...
Old Jan 14, 2020 | 10:38 PM
  #35
untamedd's Avatar
2019 AMG GT R
you might be thinking about a Non S Pre FL car. Race functionality was limited to the C63 S but now its standard.
Old Jan 14, 2020 | 10:42 PM
  #36
8cd03gro's Avatar
17 C63S Coupe
No, I have an S. I have race mode, but when adjusting the I configuration, race is not an option in the drivetrain settings.
Old Jan 15, 2020 | 01:33 AM
  #37
Tuxdude's Avatar
2019 AMG C63S
I have the Eco Start/Stop and Perf Exhaust mapped to the left side steering wheel buttons. These are always the first two buttons I press after starting the car. I have I* set identical to S+ except for Suspension which is set to Comfort.
When I start the car for the first time during the day or after a long cooldown (i.e. cold starts), I monitor the Engine and Tranny Temp. Until it turns white, I drive always in Comfort irrespective or city roads or highway. Once it turns white, depending on the mood I just stay in Comfort or switch to I*. I engage Manual transmission mode for more spirited Canyon carvings or if I want to hear the engine revs better during street driving.
I dont use S or S+. Tried it few times initially but I have found the need to keep suspension in Comfort to avoid rattles.
Old Jan 15, 2020 | 10:14 AM
  #38
velosdesignwerks's Avatar
Former Vendor of MBWorld
Mercedes C63S AMG (W205)
Make sure you are selecting the correct setting when in individual.
If you have an S the screens should look as follows when getting to the motor setting.
This is from my 2016 C63S sedan
In order from top left to right
Old Jan 15, 2020 | 01:50 PM
  #39
8cd03gro's Avatar
17 C63S Coupe
Interesting, maybe I'm recalling wrong. I'll check after work
Old Jan 15, 2020 | 02:01 PM
  #40
raudiace4's Avatar
Didn’t know that.
pre-FL S models always had race mode, you can configure Race to Individual. Non-S did not have Race mode for pre-FL.
Old Jan 15, 2020 | 03:13 PM
  #41
superswiss's Avatar
2019 C63CS
Neither for the FL. Race mode is S and higher. AMG GT doesn't have Race mode, either. Need to get at least the GT S.
