C63/C63S AMG
DINAN DINANTRONICS TUNE | AR MOTORWERKZ | C63 AMG PERFORMANCE GAINS
Old Jan 31, 2020 | 12:49 AM
AR_motorwerkz's Avatar
MERCEDES AMG GT, MERCEDES CLS63 AMG, MERCEDES G63 AMG, MERCEDES CL63 AMG
Founded in 1979, Dinan is well established as North America’s premiere tuner. Dinan develops, manufactures and markets a comprehensive line of high-performance products and systems, distributed through a nationwide network of Authorized Dinan Performance Centers that includes select Dealerships and Independent Service/High-Performance facilities.
Dinan offers a broad range of performance products from engine, driveline and chassis tuning components to complete Dinan Signature Vehicles and special Factory Works programs. As a serious Tuner, Dinan’s objective is to offer complete performance solutions for the entire range of models.
We believe that every driver deserves the opportunity to get the most from their car. From faster acceleration to improved cornering capabilites and stopping power, Dinan takes the guess-work out of creating the high performance of the enthusiast's dreams with compete, balanced performance systems.
PERFORMANCE TUNES
C63 AMG/AMG S ENGINE TUNES/POWER PACKAGES
DINANTRONICS ELITE PERFORMANCE TUNER KIT // EASILY ENHANCES ENGINE PERFORMANCE
ELITE (DINANTRONICS Performance Tuner ONLY) Maximum Power on the MB AMG C63 and C63S with the 4.0L M177 engine: 609 HP, 664 lb-ft of torque.
CALL/TEXT (818) 588 – 5403
EMAIL INFO@ARMOTORWERKZ.COM
The Dinan Difference
The DINANTRONICS Performance Tuner is a highly engineered piece of computer hardware and software that enhances engine performance to levels the stock programming is not allowed to venture into. It does this without negatively affecting your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device designed to be emissions legal in all 50 states. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
The Dinan Difference is possible by employing a full staff of talented engineers that are well rounded in many facets of automotive engineering and backed by a wealth of hands on knowledge. Stemming from diverse backgrounds not only on racing teams but on standard factory production line vehicles we have seen it all. Manipulating these signals with an adept hand all the while keeping an engine running at its best and with the most reliable power is what Dinan is all about.
Well Engineered
Plug-in tuning devices all have one thing in common, they send a modified signal to the factory ECU, telling it the boost pressure is below target values. This then causes the factory ECU to raise the boost pressure to what it thinks is the correct value. This modified boost pressure signal causes errors in fuel mixture and ignition timing. These errors can cause the on-board diagnostics systems to set faults, but they can also cause exceedingly high catalyst temperatures and a loss of power. In addition, when power is increased, exhaust gas temperature will increase as well and this must be countered with a slightly richer air/fuel mixture. The DINANTRONICS Performance Tuner has the capability to correct short term trim as well as ignition timing errors induced by raising boost pressure. This enables Dinan calibration engineers to optimize air/fuel mixture and ignition timing at elevated boost pressure throughout the entire gamut of engine RPM and engine load. Additionally, the ability to correct short term trim corrections (the difference between target and scheduled fuel mixture) remain within OEM specifications. This minimizes knock sensor activity, which in turn means smooth engine performance, catalyst protection and power increase, while this is also required to make the car emissions legal.
State-of-the-Art Hardware
The DINANTRONICS Performance Tuner is engineered using the best possible components and advanced hardware. The wiring harness uses OE connectors and expandable braided wiring sleeves ensuring that all visible components appear as if they come straight from the factory. More importantly however it guarantees long lasting and dependable performance due to the use of high heat, moisture and abrasion resistant materials and design. The other hardware element involved is the Dinan electronic control unit (ECU) itself. While its outward appearance may seem tame, the processing power and sophistication held within its internal circuitry is anything but. Capable of delivering signals to various systems at an astonishing 4000 times per second the DINANTRONICS Performance Tuner yields the power to control all current signals delivered to the ECU as well as those developed in the future without a hiccup in performance or reliability. This immense processing power equates to a high degree of engine control resulting in a much lower likelihood of setting a fault. In addition smoother running conditions and superior drivability are achieved, all of which are Dinan hallmarks.
Unmatched Warranty
Dinan's comprehensive warranty program, introduced in 1997, provides superior warranty coverage to that which you would find elsewhere. If your vehicle is currently covered by the vehicle manufacturer's new car limited warranty, Dinan® products are warranted for the remaining term of the vehicle manufacturer's new car limited warranty. The manufacturer's new car warranty is limited to 4 years or 50,000 miles (80,000 kilometers in Canada), commencing on the date of first retail sale or the date the vehicle is first placed in-service as a demonstrator or company vehicle, whichever is earlier. Dinan's warranties are transferable when ownership of the vehicle into which the Dinan products were originally installed is sold. Mercedes-Benz automobiles can now be performance-tuned without the associated concern of negatively affecting the new car warranty coverage.
Designed to be 50 State Emissions Legal
The DINANTRONICS Performance Tuner was designed and built to be the only tuning box on the market
that is emissions legal in all 50 states. CARB EO has been submitted and approval is pending.
Drivability
There is more to a tune than just cranking up the boost. Power needs to come on smoothly and in a predictable way to make the car
as fun to drive at wide open throttle as cruising around town. It is your Mercedes, but reborn with new found acceleration and speed.
Installation
Installation takes roughly 4 hours.
Easy To Use
Dinan's ECU is Bluetooth capable. While a smartphone app is currently being developed we have also included a physical bypass plug
that can be used, should the need to arise, when you want to revert to stock without disconnecting the entire harness.
Designed for the Future
The DINANTRONICS Performance Tuner was engineered with future expansion of functionality in mind. Boasting the most powerful processing power on the market the DINANTRONICS Performance Tuner can handle more functions and processes than any of its contemporaries. To that end the Dinan performance tuner is capable of interfacing with much more should the need arise down the road. This means that when new functions are developed there will be no need for a new tuning module. Simply a short software update at your local Dinan dealer. Potentially a supplemental harness may be needed to take full advantage of more advanced future development.
Max HP Gain 84@4500 RPM
Max Torque Gain 126@2500 RPM
Peak Horsepower 609@5000 RPM
Peak Torque 656@2500 RPM
Peak HP Gain 55@5500 RPM
Peak Torque Gain 82@4000 RPM
Factory Rated HP 503 (533 Measured)
Factory Rated Torque 516 (572 Measured)
Want Something From Dinan But Was Not Listed Above? NOT A WORRY We Got Your Back!
Send us a message to our phone number or text us at the number below to inquire about all the other products Dinan has to offer!
How to Place Your Order With Us
Phone Domestic: 1-818-588-5403
E-mail: info@armotorwerkz.com
Website: www.armotorwerkz.com
Please do not hesitate to contact us should you have any questions.
We have over 70 years of combined experience and 13 years of hands on experience in the automotive industry.
All orders are processed via Paypal invoice or Quickbooks invoice.
Shipping:
All orders are shipped via UPS Domestic and International.
If you are located in Hawaii, Alaska, or international, please e-mail, pm, or call us for the most competitive rates.
Hours of Operation:
Monday through Friday from 8:00 a.m. to 6:00 p.m. PST
Saturday from 9:00 a.m. to 3:00 p.m. Pacific PST
Our website is open 24 hours a day / 365 days a year!
Contact Information:
Direct Line: 1-818-588-5403
Email: info@armotorwerkz.com
If you have any questions or concerns, do not hesitate to contact us. We are here to help you!
Attached Thumbnails DINAN DINANTRONICS TUNE | AR MOTORWERKZ | C63 AMG PERFORMANCE GAINS-dinan_-dinantronics_elite_performance_tuner_c63_c63s_d440-0054_6-e1517866185417.jpg
