C63/C63S AMG
Are all AMG bi-turbo 4.0L engines created equal?
Old Feb 4, 2020 | 05:23 PM
mfissel's Avatar
2020 C63S Coupe
Does the long block of the 503 HP C63S have the same components as the bi-turbo 4.0L in the 550 HP AMG GTC or even the AMG GTR? Does Mercedes just de-tune this engine depending on what platform they put it in?
Old Feb 4, 2020 | 05:39 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
From what I read, not much hp more but the short block are built with higher end materials.
Old Feb 4, 2020 | 06:12 PM
superswiss's Avatar
2019 C63CS
No, it doesn't. The various power levels have different turbos. Our variant has single scroll turbos and the higher output variants have twin scroll and larger turbos. Also specifically for the GT, the GT variants have a dry sump oil system to lower the center of gravity and keep the engine lubricated properly during high cornering forces. The base is the same, but the higher power levels are essentially achieved with different turbos and ECU tuning.
Old Feb 4, 2020 | 07:24 PM
benzbell's Avatar
2023 Urus Performante 2018 Huracan Perf. - 2017 Ferrari 488 GTB
Boost pressure is also different among some of the variants. In addition a dry sump reduces crank drag somewhat which allows the engine to rev more free and faster.
Old Feb 7, 2020 | 11:59 AM
nobbyv's Avatar
2016 Cardinal Red AMG C63 S
[QUOTE=superswiss;7972127 the higher power levels are essentially achieved with different turbos and ECU tuning.[/QUOTE]
That's good enough for me to tell myself it's the same engine. Hell, I tell myself my car has the same engine as the Aston Martin Vantage at about half the price!
Old Feb 8, 2020 | 10:43 PM
Klinh's Avatar
LOL ... you might as well put the Aston Martin Vantage badges on your car. 😄
Old Feb 9, 2020 | 07:59 AM
SimMB's Avatar
C63S
I've just been reading that the C63 is putting out 9.5psi of boost? So the S is what, 11psi?
Surely a tune is a pretty safe bet on these cars?
On the subject of tuning. That vid on the of home page, Sandra's car was pushing 624hp, yet Litchfield only get 570, or 590 with the Akrapovich exhaust.... I'm thinking it's a bit of a minefield out there..
Old Feb 9, 2020 | 02:58 PM
DRGG's Avatar
C63S AMG Coupe
I also read where compression values are different and different alloy in piston heads for example in the E63. Engines with higher output have stronger parts.
Old Feb 9, 2020 | 04:32 PM
DWK_C63 S T's Avatar
C63 S Touring
that would be sad. Besides, the C63S has more torque than the Vantage and DB11 V8
Old Feb 9, 2020 | 05:21 PM
superswiss's Avatar
2019 C63CS
You are correct. I forgot about that. Each variant has different pistons. They showed us that during the factory tour. Each engine starts with the same block, but gets different pistons, turbos etc.
Old Feb 11, 2020 | 08:00 AM
wassup61's Avatar
E63S4S
Compression ratios are definitely different between the E63S and C63S.
The E63S is listed at 8.6:1 and gets larger twin scroll turbos
The C63S is listed at 10.5:1 and has smaller single scroll turbos
