C63/C63S AMG
Clearing permanent CEL code
Old Mar 7, 2020 | 01:40 PM
ggonzaga's Avatar
2020 E63S
I've been getting a P0456 code (small EVAP leak) that comes back 1-2 days after I clear it. It's listed as a permanent code. I've taken the car to a shop that inspected the EVAP lines thoroughly and they can't find anything wrong with the car. I have a secondary cat delete, but that has nothing to do with the EVAP system. However, because of the cat delete, my service advisor doesn't want to lift the car as they would see the exhaust modification and void the exhaust warranty. There is nothing wrong with the car, and I'm wondering if I can just buy an iCarSoft MB V2 OBD scanner to clear the permanent code? I have a crappy OBD scanner that clears CEL codes but not the permanent ones. How could I go about getting rid of the code?
Old Mar 9, 2020 | 08:52 PM
Haji3978's Avatar
C63s Coupe
Check your fuel cap too ..
Old Mar 10, 2020 | 06:23 AM
tekfoc's Avatar
Veteran: Army
18 E63S
This
Old Mar 10, 2020 | 10:09 AM
E55Greasemonkey's Avatar
This place is a joke.
You clear it by first repairing the fault. There's no such thing as a "permanent" fault code, only "current" or "stored."
Old Mar 11, 2020 | 12:01 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I think he meant by remove the faulty code like in a tuning with down pipes that tuners would do by turned off the O2 sensors.
Old Mar 11, 2020 | 01:34 AM
Haji3978's Avatar
C63s Coupe
Probably not the best idea to code it out something this important in case something does go wrong ...
