C63/C63S AMG
BIG Power, Simple Mod, ModalWorks Intake
Old 08-10-2020, 10:10 AM
  #151
IvanC63S's Avatar
2016 C63S
My butt Dyno thinks so. Take that for whatever it's worth.
Old 08-10-2020, 10:29 AM
  #152
tobeit's Avatar
AMG C63s
Can I borrow your butt dyno for a day ...mine is broken.
Old 08-10-2020, 01:49 PM
  #153
LessIsMore's Avatar
2017 AMG C63
Originally Posted by ModalWorks
Without hearing it myself, my first thought is that it is likely the re-circulation valves doing their job. They are working at times we as drivers don't expect them to, in order to modulate and regulate boost pressure. Our intake system (as you're already aware) open up the auditory notes of the induction sound which also means we hear more of the re-circulation valves. It makes sense at low throttle or at WOT you don't notice this since they are likely fully closed; but during medium throttle pulls they are working their magic (they seem to be very active on our cars and are constantly working based on ECU commands).
Hey thanks, appreciate the response. I think you are right that the diverter valves play a much more active role with our engines then I have seen on others. I do not necessarily think this is a problem, will keep an eye on it.
Old 08-10-2020, 04:04 PM
  #154
AlexZTuned's Avatar
2017 Porsche 911 C4
I’m running stock software at the moment and I can absolutely feel the difference. Stock software does not taper off HP to redline like a tune with stock turbos, so to me that linear powerband and the extra puff up top with the intake installed really wakes up the car - especially the top of 3rd/4th, where you’re spending more time above 5k rpms.
Old 08-12-2020, 01:35 PM
  #155
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Mine came in today, so will get it installed in the next day or so... :-)
IvanC63S (08-12-2020)
Old 08-28-2020, 01:27 AM
  #156
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
These look great
Old 08-28-2020, 08:29 AM
  #157
FLC63s's Avatar
Here are a few pic during/post installation.
I will clean up my car/engine area this weekend and take more pics. (been swamped at office)
ModalWorks (08-28-2020)
Old 08-28-2020, 04:21 PM
  #158
skratch77's Avatar
2005 E55
I just got my kit and there is no instructions. Its pretty straight-forward but where do we put the sensor that sits ontop of the stock intake?
Old 08-28-2020, 04:58 PM
  #159
AMG82's Avatar
2020 C63s Coupe
Instruction here.
https://cdn.shopify.com/s/files/1/03...f?v=1596080351
Old 08-28-2020, 05:14 PM
  #160
IvanC63S's Avatar
2016 C63S
I just zip tied mine back.
Old 08-28-2020, 06:01 PM
  #161
LessIsMore's Avatar
2017 AMG C63
Yes you can just zip tie them back or hang them out of the way somewhere. Just remember to remove the sensor from the factory Box and plug it in to the harness so you don't get a code.
Old 08-29-2020, 09:09 AM
  #162
FLC63s's Avatar
what do you mean ?? I pulled my sensors (map) one on each side, and there is nothing to plug then back into ???
you just zip tie then down (to harness is fine)
but what are you referring to that needs to be plugged in ??
Old 08-29-2020, 09:17 AM
  #163
IvanC63S's Avatar
2016 C63S
It's only if you take the sensor apart from the harness for some reason.
Old 09-28-2020, 04:55 PM
  #164
Amer Khan's Avatar
e400 coupe
So question is there any way we can remove the top speed limiter? What’s the point of better torque and hp when you can’t push it to over 130mph..
Old 09-28-2020, 06:19 PM
  #165
tobeit's Avatar
AMG C63s
a tune does that for you 😑
Old 09-28-2020, 08:00 PM
  #166
SPONSOR
ModalWorks's Avatar
W205 C63
We got a few sets of filters in today and currently have 2 complete intake systems in stock. With the purchase of an intake we will throw in a turbo blanket 1/2 off with promo code HalfOffBlanket.
Old 09-28-2020, 10:27 PM
  #167
mr747's Avatar
c63
I have sent you a email from brad@dyneperformance.com.au
Please answer
Old 10-09-2020, 05:14 PM
  #168
SPONSOR
ModalWorks's Avatar
W205 C63
These units are back in stock, the promo code for 1/2 off the turbo blanket is still active as well!
Erik Apple (12-17-2020)
Old 12-21-2020, 12:09 AM
  #169
AMG82's Avatar
2020 C63s Coupe
I finally got it installed today. I had some problem installing air filter to carbon intake tube myself as filter kept slipping off while trying to tighten the clamp.
I had to call another person to hold both intake tube and air filter together while I tighten down the clamp. Other than, installation was pretty straight forward.
Like everyone mentioned, I definitely noticed more top end power even on stock tune.
It’s gonna take few more driving for me to get used to those additional induction noise.
ModalWorks (12-21-2020)
Old 12-21-2020, 07:55 AM
  #170
FLC63s's Avatar
Thats AWESOME... yea I love the sound as well... I have Renntech BOV's as well, so on aggressive driving, there are lots of sounds going on...
AMG82 (12-21-2020)
Old 12-22-2020, 04:57 AM
  #171
ShaneN.'s Avatar
2018 e63s edition 1
Do you just cap off the recirculation holes in the carbon fibre portion just the same as if you had the stock intakes?
Old 01-09-2021, 03:56 PM
  #172
AMG82's Avatar
2020 C63s Coupe
I made a mistake of over-tightening air filter clamp when re-installing intake and it ended up putting a deep cut on the filter flange.
I was looking to purchase replacement air filter (aFe 21-91122), but pretty much every place including ModalWorks and aFe had nothing in stock for a month or so.
After looking at multiple performance filter company, I realized that it was impossible to find exactly same size filter that comes with ModalWorks intake.
However, I found dry flow filter from AEM that is 2 inch shorter in height but has slight larger top and bottom diameter compare to aFe filter.
I ordered these filters from Amazon and with help of 0.25 inch width O-ring (because inner flange length of AEM filter was only 0.75 inch vs. 1 inch from aFe filter), I made it fit perfect and tight inside box.
Other thing I added to it was pre-filter which provides protection against dust and liquid for peace of mind.
Quick test drive shows no noticeable performance decrease vs. longer aFe filter, and no reduction of intake noise. Actually, I feel like noise is slightly louder with shorter AEM filter for some reason.
Anyway, just posting this for information purpose. It may be helpful for those who live in desert area or drive during heavy rain season.
Link to purchase filter:
Amazon Amazon
Link to purchase pre-filter wrap:
Amazon Amazon
Link to purchase 0.25 inch width O-ring to extend flange length:
Amazon Amazon
Here is pic of ModalWorks intake system installed with AEM filter + pre-filter.
I also want to mention that ModalWorks customer service is exceptional.
I lost few screws due to my mistake, yet ModalWorks sent me those replacement screws free of charge!
Erik Apple (01-09-2021)
Old 03-08-2021, 12:25 PM
  #173
Bodhi225's Avatar
2019 AMG GLC 63S
Oiled vs. Dry Filter?
The site offers both Oiled & Dry filter types,
Which of these would be better and why?
Are they both easily serviced vs. replacing at intervals?
New to the forum, just picked up a 2019 GLC63s, Actually has not been delivered yet (due today)
Only 7K miles, looking forward to Driving it!!
Old 03-08-2021, 05:52 PM
  #174
AMG82's Avatar
2020 C63s Coupe
I like dry filter. It is easier to maintain and there is zero chance of messing up any sensors.
I think performance difference between oiled vs dry is pretty negligible.
Old 05-11-2022, 06:58 PM
  #175
SPONSOR
ModalWorks's Avatar
W205 C63
It's been over a year since we have bumped this thread and in that time we have had tons of customers adding more horsepower to their vehicles, one exciting example is from a set that was installed last week on a stock turbo C63.
A customer provided dyno and dragy data showing 70whp gain. They also backed this up with back to back dragy runs showing a 0.41s improvement. The only difference between the dyno and dragy are the change in intake. Our intakes consistently produce the most power and were used on the current world record 1/4 mile W205 C63. Data doesn't lie and we are pleased to see many other are matching and exceeding our initial claims.
Quick Reply: BIG Power, Simple Mod, ModalWorks Intake
