C63s Misfire, Check Engine Light, Rough idle but fixed itself up?
After leaving the car overnight, I turned the car on and there was no issue at all. Idle was good, performance was normal.
Today I drive it and it starts to shake again and CEL comes on. Then I leave the car idling for about 5 minutes in Neutral and the idle returned to normal and car was good again
I'm getting a P0305 Misfire on Cylinder 5.
I don't know what it is and I have it booked in to the workshop on Monday morning. My question is, if it was a bad coil or spark plug, wouldn't the rough idle be constant and not "fix" itself up after letting it idle for a while?
If anyone has experienced the same thing or has any idea what this is, I'm all ears.
Thanks fellas.
But remind me...does your car have any performance mods???
I'm at 55,000km (35,000 miles) on the odo. Man I hope it's not some big engine problem as my warranty ended 3 months ago.
The misfire is always showing on cylinder 5. No other codes!
Keep us informed and Good Luck my friend!
Now that you've mentioned it I was thinking it could also be this because the misfire resolved itself when I left the car idling for 10 minutes but happened again later on when I drove it
Coincidentally I have just filled up a full tank. Can I ask you, did your misfire happen on just one cylinder? How did you fix yours? Would letting the car idle for 30 minutes be ok?
... that one caused misfire codes mostly when idling but also sometimes when under WOT above 6K RPM.
https://www.youtube.com/watch?v=M7WXHEsuh_Q
... just change all the plugs not just that one
..SOLVED!
Spot on brother, it was a bad coil which also zapped the spark plug!
The bad spark plug was actually caused by a failing coil so they replaced the bad coil and all the plug now she's back to her old self again (thank you lord). Cheers to all of you who took time and posted here.
PS: For anyone looking for it the coil part no. for C63s M177 4.0 V8 it's A1779069500 they cost over $600 AUD each brand new from Mercedes and our engines have 4 x coils in total - one coil on every two spark plugs.
You can get them cheaper (used) on ebay if you really need them urgently but I wouldn't get a second hand one especially if you are tuned.
Yeah that's a bad plug for sure, thanks for the video.
Thanks man. Can I ask you, during the bad fuel incident, were the two misfires on the exact same two cylinders all the time?
4 months out of warranty 52500 kms
Thanks fellas.
Edit
. Hopefully that will take care of the problemthank you.
Could have turned out a lot worse. If you're having a similar rough idle issue, start by changing and inspecting the plugs and that will likely resolve the problem. And if not, you'll have fresh plugs and know it's likely a bad coil.
Both misfires happened in sport plus, once in heavy stop go traffic and this time cruising on highway.
