Carplay 2017
Carplay 2017
Hi guys
I have read many info about this, but not very conclusive.
Any option of installing carplay in my 2017 c63s coupe with stock screen? Cannot use the OBD cause my car is June 2017 😬
Have any of you gone that way?
Many thanks!
Many thanks!
Yes, Unichip, Joyauto and others sell plug and play units that you can use. However if you're going that route, I would suggest just get an aftermarket android screen that comes with carplay.
Actually I do have an aftermarket screen with carplay, but somehow not comfortable enough knowing is not oem, even considering it works correctly
Thats why I am thinking on going back to oem with CarPlay and having all original controls from console and all
https://m.es.aliexpress.com/item/400...bilesitedetail
japamg (03-27-2020)
do you have command or audio 20 in your c63? if you have audio 20, there is an oem option. if you have command, only aftermarket is option. or you can "downgrade" to audio 20 to get oem carplay. you sacrifice 1" of screen. but it sounds like you may value the oem flawless integration vs having the biggest screen money can buy.
japamg (03-27-2020)
No, downgrade not an option, 8,4” is in the limit of what I consider acceptable
I tryed joyeauto carplay. Received very fast. The installation is easy, but i had problem to locate the box itself. There is no place underneath the command.
Finaly tryed, but had some problem with using. Navigate between carplay and original system. Its not working like oem carplay.
I sent back.
I sent back.
I sent back.
I sent back.
