Lets talk lowering
I wouldn't mind slightly higher tire wear but it sounds like some people are literally seeing as low as 3-5000 miles on the front tires before they insides are worn (feel free to chime in if that's not the case for any of you). That mixed with likely less than desirable handling characteristics with too much negative camber, I'm thinking it's going to be a must to adjust that. How out of spec for camber will the rear be when lowering with h&r springs (an example for height)? I've read a bunch of threads saying we're around -1.5 or -1.6 stock in the FRONT and go to about -2.5 after lowering. However, don't hear much about adjusting the rears.. wouldn't they be just out of spec? Just looking at my car stock height I can visually see the rears have a bit of camber already, although I just took off my rear tires at near the wear bar and they wore evenly right across. If I can get away with just doing the front, that'd save a bunch of money and time.
It appears like the two main options are either a kmac bushing kit or a f1 fabrication adjustable control arm. I'm really leaning toward the f1 fabrication control arms for the front since they seem to be a simple way to go but also a more straight forward/cheaper install option too. I'm curious to what other people's experience has been with them. Aftermarket control arms scare me a bit, as far as how strong they'll be. I'm also reading that you should opt for some factory bushings in them so they're quieter. Is there any better/different options I may have over looked?
Another thing I keep reading about values being exceeded and logged after being lowered when driving hard. Is this only when the camber isn't corrected? If not, is this an issue at all? I assume it's not causing a CEL and just comes up when running a scan for codes?
And finally, how do lowering springs make the car handle? In my forum searches I keep reading people seem to think the ride is somehow softer after various spring installs which I'm not really worried or care about, I more so want to make sure the car stays at least as stiff and planted in the corner. I'd assume the car being lower would have less body roll but maybe not if it's a softer feeling spring (fwiw i don't want to go full coilover setup)?
For you guys that have done this already, let me know which route you've gone and what your experience was. I'm more interesting in hearing about getting the alignment acceptable without spending an arm and a leg (just doing the front?). I've also already decided what route I'd be going for the springs.
(PS: I have 2 other, moderately lowered cars on spring kits - one with similar whp - and neither show significant more tire wear than usual - but guess also depends how you drive and how your none-lowered tire wear is to start with ;-))
In this video the guy talks about at 4:20 on his c63 coupe. The inside wore so bad they wouldn't hold air but in the picture it looks like the rest of the tire is almost new
https://youtu.be/yoELuk-MaE4
My alignment has corrected ft camber as to not wear tires as bad but I don't like the feeling , feels a bit sloppy and I've had it checked 4 times .
At this rate I'm tempted to throw some h&r springs at it and just see what kind of life I can get from my tires and go from there. Seems like an expensive game to play though.
I would not say most will have this experience.
Background to C63 (similar kits all 1968 to 2020 models)
FRONT - '2' VERSIONS MANUFACTURED:
# 1. Performance / Track days
#503316 K $480 (to 14th May $360). This kit also provides "tauter response" - replacing the 4 front main lower arm / highest wearing suspension bushings.
Precise, single wrench adjustment (accurately under load - direct on alignment rack).
Up to 1.5 degrees 'extra" Camber (Pos. or Neg.) Which is '5' times adjustment of the OEM, inaccurate, one offset position, fluted bolts available for earlier models.
This lower arm adjustment also allowing extra 30mm track width for performance/track days.
Bush extraction tool included. Fail safe lock system - bushes cannot inadvertently loosen.
While for the forward facing Thrust Arms (Caster adjustable bushes) - these are Monoball / 2 Axis design, eliminating the soft rubber, oil and air voided OEM bushings.
Result is tauter, significant improvement to brake and steering response.
This unique KMAC design allows more than twice the load bearing and impact area of steel spherical bearings. Finally resolving the issue that has plagued the industry - their wafer thin teflon liners soon pounding out.
While #503316-2J $380 ($285) FRONT UPPER ARM ADJUSTMENT:
# 2. Main features incorporated into this design is "Both price, ease of fitment and install without need for arm removal - bush extraction tool included.
Provides precise adjustment of both "Camber and Caster" up to 1.5 degrees Pos. or Neg. Design also allows the advantage of retaining the security, peace of mind of using OEM high strength forged alloy arms. Not welded, fabricated upper arms.
Note: When combined with the "lower arm" kit. Provides serious adjustment on Track days - effectively doubling adjustment range (up to extra 3 degrees negative Camber).
NON FRONT UPPER WISHBONE MODELS - INSTEAD UPPER "STRUT" MOUNTS: KMAC Replacements Camber and Caster kits.
Stage 2 (Street / Race) or Stage 3 (Full Race). Precisely adjustable from engine bay.
REAR - LIKE FRONT - ONLY TOE ADJUSTMENT OEM:
#502226 K $480 ($360) Rear Camber and importantly extra Toe adjustment to compensate
Replaces the lower arm inner bushings (bush extraction tool included). Same design and adjustment range as front.
Advantage over upper rear arms is retains essential clearance "top of tire to outer fender when wanting to reduce inner edge wear, increase traction
Single wrench adjustment - track days allows easy access for dialling in maximum traction.
#502628 K $480 ($360). Uprated performance bushings (supersedes short life delrin bushings) for the '6' rear multi link arms. Less twitch, flex, loss of traction. Especially when applying power to lane change / overtake.
Kevin
Delivery $40 one kit ($20 each extra).
To access the 25% discount offer - email address and use Toll free #1888 847 9099 (24/7) for Visa or M/Card payment.
I think I may have been one of the first to fit to the W205 C63S and have never run into any issues.
If I just do h&r springs how likely is it to actually blow the shocks? Also, is everyone lowered actually taking their cars into mercedes to have them adjust the ride height sensor.
Seems like so many people lower without any issue other than tire wear which is inevitable but someone also comes in with a comment about the above. If tire wear is likely to be my only issue I'm thinking about just throwing a set on and seeing what kind of wear I get from my tires and going from there on what I might order to correct camber in the front or rear.
On a side note, who installed your springs?
i lowered all my cars and have 3 lowered cars now - anything from springs, to HAS to full coil over. Never regretted it ...except some spring kits are not balanced well (like Eibach tend to lower back more then front - happened to me on 3 cars and ended up changing to something else). Shock wear happens ... with or without lowering but mostly an issue when starting with low end, low quality shocks. If so, I change to Bilstein and problem solved.
don’t debate and over analyze / if you like the look and better handling - lower it. If not, don’t.
