😒 CONFIRMED: FACELIFT C63S HAVE SMALLER TURBOS
#51
Seems all PFL owners are.
And that's great! We should all love our cars.
But I don't get why almost every PFL owner does everything they can to make their car look like a FL.
Might as well get a FL and fix the sound, rather than get a PFL and change everything about it.
Wexlax732 (05-20-2020)
SimMB (05-18-2020)
#53
Mate just sent me a vid of a lad hitting 200 in his mapped C6 RS6, not 100% sure though, it's hard to make out which number the needle is on, proper squint fest, don't know how you analogue boys cope!
#54
Weird, then again, I'm sure I read on the headlight thread you guys in 'murica don't get the full lighting effect. They're pretty impressive, they must have been designed by Baron Samedi; full on witch doctor voodo shiz, blocking out the car Infront and lighting up the road all around it. When the beam comes back on it scrolls across like the opening of curtains, it's like show time!, que quick right thumb smash on the mode button to I, and bury the throttle! 😅
Your mate's speedo number means nothing since it's not GPS verified 😋 We, or at least I, cope by using acceleration measurement tools like Dragy, VBox, and the good ol' 1/4 mile strip.Preface lift or not, we can all get a GIGANTIC speedo readout in the central screen:
It looks pretty clear to me 🙂
#55
This thread is pretty annoying by now but statements like that make it plain wrong. Similar like the statements PFL owners want to save money as they bought mostly used. All garbage statements generalizing w/o knowing a thing.
Jimmy_c63s (05-19-2020)
#56
19 E63s, 23 M3 compX, B9 SQ5
Lol well some of us bought our PFLs close to the time they first hit the market, and are happy with the decision. (Bought my 17' in Feb 2017 with 4K miles on it). Only thing I like about the FL is the Panamaericana grille, and that's updated on mine. Aside from that nothing else I want from the FL, especially not the smaller turbos LOLLLLLLLL
#57
My lights move around corners and automatically turn on/off the brights with oncoming traffic, so if I can see where I'm going clearly that's fancy enough for me 👍
Top speed speed run in S+! 🤦♂️
Whoever produced that vid with the wrong AMG badge overlay deserves a punch in the face!
#58
100% of the time I have it in the AMG mode to display engine oil and trans temp, then once it’s up to temp, I switch it to the G-Force gauge and leave it on there. That’s my procedure for each drive 🙂
I also have a *gasp* digital heads up display that also shows me speed, gear, rpm, etc. These PFLs are ancient though without the in between COMAND/MBUX solution MB came up with until they started rolling out their next gen MBUX on all cars standard. You already have outdated tech that’s standard in an CLA now...
And yet, I still prefer the way my analog gauges look. I can get my speed and gizmos from the center screen or HUD or what have it....
#59
There’s a difference between redundancy and functionality. That pic was just an example that you can get a clear view of speed even with analog dials.
#60
You simply can’t beat physical gauges in terms of pure beauty.
#61
Owned a 991 911 GTS and didn’t care for the gauges. Goes the other way also. I think Bmw took a step backwards with their digital gauges design. Luckily since its digital, it’s easily fixable.
#62
Received 3,720 Likes
2019 C63CS
So, the main reason I like the digital instrument cluster and much prefer it over the analog gauges is the Supersport layout that puts the rev counter front and center, along with the current selected gear and eliminates the speedometer in favor of a digital readout. In addition the left and right areas become available to display two independent sets of information I can choose depending on the driving situation. I most often have the performance display on the left, and the tire pressure/temperature display on the right. When doing a trip I may bring up the turn-by-turn navigation instructions on the left and the map on the right etc. Lots of choices.
Some of the performance cars and examples above have done this right with the analog gauges by placing the rev counter in the center and move a smaller speedometer to the side, or also completely eliminate it in favor of a digital readout. The traditional side-by-side speedo/rev counter just isn't sporty. It's what you get in a Toyota Camry. If you like that kind of arrangement, the digital cluster still gives that choice. I personally find the analog speedometer a complete waste of space. I know, some argue that besides indicating the current speed it also shows the rate of acceleration via how fast the dial moves, but I have my butt dyno for that.
We can argue about the beauty of sculpted gauges and some do indeed look like a piece of art, but quite honestly the ones in the C63 aren't particularly pretty or anything to write home about, but most importantly they are stuck with the side-by-side layout. I think it would be completely different story if the PFL AMGs had analog clusters like the examples above with the rev counter in the center to actually make it feel and look sporty. I personally opted for not getting the heads up display. Not a fan, especially since I wear polarized sunglasses. The traditional side-by-side gauge layout has long bothered me in these cars, and I was really happy that AMG and others have seen the light and offer the Supersport type layouts. By the way the other awesome feature of the digital cluster are the prominent shift light animations that make the whole cluster flash red to make sure I don't run into the rev limiter in manual mode. They've done an excellent job to see information like that in one's peripheral view while keep your eyes focused on the road ahead.
It's the customization that really sets the digital clusters apart. Those who like side-by-side gauges, can have them, but those like me who really think in a car like this the rev counter and current gear should be front and center have that choice along with being able to display other relevant information in the space that's no longer wasted by a giant speedometer.
#65
2023 Urus Performante - 2021 Ferrari Roma - 2017 Ferrari 488 GTB - 2022 GLE 63 S Coupe
Even with digital you are still glancing down for a split second or focusing on your peripheral to see when to shift. It's still a minor distraction no matter how you cut it. This is why I like the head up display so much. Eyes are 100% on the road and the matter at hand instead of 90% like with the digital. I've had the head up display in both of my C63's and have clocked over 30k miles between the two of them. I've had no issues whatsoever.
#66
2019 C63CS
#68
I think it would be hilarious if it turns out this shop was completely wrong about this..and this thread just turned out to be another FL vs PFL grudge match 😂
#70
I checked and PN's are the same as well, both showing 177-090-00-80 regardless of whether it's for a 2017 or a 2020.
#71
#73
What's the manufacturers part number?
One bloke in Australia, whips his calipers out, takes a few measurements of a turbo and categorises the entire product line. Pretty ridiculous really.
#74
I don't know if the FLturbos are bigger or not (great for me if they are) but I know we need more confirmation than one shop's tweet before concluding.
#75
I have copied renntechs email to me below:Good Afternoon,
Thanks for the email. Yes, it’s the same tune as the prefacelift model, so it will def work with your 2020 model.
https://renntechmercedes.com/index.p...205_c63-detail
Regarding the turbo size, they are the same size, whether it be a pre facelift or post facelift model.
Please let me know if there are any other questions.
Sincerely,
Patrick Casey
Product Specialist
7825 SW Ellipse Way
Stuart, FL 34997
Direct: 772-266-9024
Phone: 561-845-7888 Ext 114
Fax: 561-845-6777
patrickc@renntechmercedes.com
www.renntechmercedes.com
RENNtech on Facebook
RENNtech on Instagram
Show quoted text
Sincerely,
Patrick Casey
Product Specialist
7825 SW Ellipse Way
Stuart, FL 34997
Fax: 561-845-6777
Show quoted text
