C63/C63S AMG
Fault Code P002477 - 2017 C63S
Old Jun 3, 2020 | 01:12 PM
redonettii's Avatar
C63S
Hi everyone, I tried to search on the forum to see if this had been answered before ...
I am seeking to purchase a second-hand C63S AMG Saloon, its my dream car. I found a good 2017 example with low mileage (12,000 miles or 20,000kms), from a private dealer, who told me that the first owner of the car neglected to service the car before selling it to the dealer. As a result, the car is overdue for its A service by about 7 months.
I had a pre-purchase inspection done on the car which came back totally clean except for one thing - the car idles a little irregularly (the mechanic told me it was very minor). He said he found a stored fault code P002477 (pic attached). From my Googling, it seems that this could have been caused by the failure to service the car on time for its last annual service and there may be old / dirty oil in the engine : "The oil is too thick, causing the passages to become clogged due to lack of oil flow to or from the camshaft phasers that control the timing."
I was just wondering if anyone else had seen this before and could shed any light on it - is it a serious problem or one that can be fixed by servicing the car? I'd be able to get the car for a pretty decent price and the rest of it is in pretty good nick.
Thanks in advance!
Old Jun 3, 2020 | 01:30 PM
TeraPatrick's Avatar
C63 AMG
That's an inexpensive fix. One of the cheaper ones actually, should be under 300. I would be more concerned if the original owner has had it tuned at some point. You don't want to buy a vehicle that has potential to be flagged. My car is tuned and I try every other option before having to take it to the dealer. I had to pay out of pocket for small minor repairs because I'm afraid of being flagged even though I'm cool with the SA and Mechanic at my dealer.
Old Jun 3, 2020 | 01:35 PM
redonettii's Avatar
C63S
Thank you TeraPatrick - may I ask, how would they fix it? I don't think it has been tuned - the car has been left in a garage for some time as the owner went overseas to live and left it behind (madness), but I am taking it to a Mercedes-Benz specialist garage tomorrow just to be sure and check, the car is still under warranty at the official Mercedes distributor for another 18 months, however I suspect the warranty might be voided because it has not been serviced on time - if this is the only problem with the car and it otherwise has a clean bill of health I hope it will be a good buy!
Old Jun 3, 2020 | 02:13 PM
C63 AMG
It's an awesome car. I'm not a mechanic myself, but he's dealt with same code on my friends car and it was around $300. I understand the original owner was overseas hence not servicing the car. But does the mileage of the car (since its not driven) match the mileage on the expected service date mileage?
Old Jun 3, 2020 | 02:33 PM
redonettii's Avatar
C63S
Yes I think so ... the Mercedes dealer gave me the history - serviced October 2017 at 7,000kms, then October 2018 at 12,400 kms, and was supposed to be serviced at October 2019 but missed it’s service. It last came to the shop to fix a paint scratch on its rear bumper in July 2019, when it was recorded with 17,000kms on the odometer. Car was sold by previous owner in February of this year to the current dealer with 20,370 km on the clock (20,382 now). It seems legit to me (I think?) I’ve had it inspected and they said the odometer was fine, but I’m sending it for inspection tomorrow with a Mercedes specialist to check out the code! Hopefully they’ll be able to tell me whether it’s ok to buy!
Old Jun 3, 2020 | 03:44 PM
C63 AMG
Best to wait for the big boys to run their diagnostics and see if she's worth it. If all is good, this car will put a smile on your face every time you turn it on.
Old Nov 17, 2020 | 04:49 PM
Ahmed MAG's Avatar
C63 AMG
What happened then!!
Hi friends, I have 2018 C63 AMG, and having the same code, searching and googling but nothing, I wonder if you have fixed the problem and what is the issue was.
thank you
Old Nov 4, 2021 | 06:49 AM
Opelveve's Avatar
W203 c180 2007
Did u know what is the issue and did you solve it ?
thank you
Old Apr 22, 2024 | 10:31 AM
brandonc63's Avatar
2017 c63s c205 amg
thank you
hi there
I have this issue on my c63s 2017 coupe and wondering if it’s fixed and what the cause is/was
thanks
Old Aug 4, 2024 | 12:28 AM
eedww's Avatar
E63s AMG 2017
Thanks in advance!
Hi. I have the same in E63s amg 2017. Same rough idle and fault code. Im using my car 2 years with this problem, 20.000km yet.. no other problems , just this small problem.. Did you know the solution maybe ? Or any of you , guys ?
Old Aug 9, 2024 | 10:09 PM
W140King's Avatar
W140 S320
Does anyone have an update on this? I have the code stored in my ECU but its not current. Just a stored code. No rough idle or CEL though.
Old May 25, 2025 | 07:44 AM
Nabil Hamzeh's Avatar
hey im having the same problem on my 2020 s560 i recently bought the car used at 25k miles and drove it for 2 weeks when the engine light came up i scanned it and found the same code idk if it is a big problem and i should sell the car or if i should keep it and fix it.
Old May 25, 2025 | 11:39 AM
eedww's Avatar
E63s AMG 2017
solution
if you've bought your car recently or if you have a problem with fault code like descripted you just need to flush you engine oil system with OILSYN Release Power Flush, its working very well, no codes after engine flush 2 procedures. By the way i flushed my oil system x2 times : 1st - immediately and 2nd - after 2k km and changed oil 5w40 to 0w40 (dont use Castrol, pls use Motul, Millers, Mobil1, Petronas 229.5 MB only approved oils (check their list). If your oil is black during changing procedure after next 5k km - flush again.
During flushing procedure make it longer (40-60min instead of 15min) then Oilsyn recommend and use x2 (double) bottles of flush cleaner then Oilsyn recommend when you will do this for the first and second time. Next just change your oil every 7-8k km with normal flushing every time (1 bottle as Oilsyn recommend).
When i finished my cleaning x4 times i have actually dark brown color of oil after each 8k km changing oil , not 100% dark black as it was at the 1st and 2nd time.
