First look at the new AMG/Garrett electric turbocharger - destined for W206 C63?
I think this is also a good indication/hint that the 4 cylinder rumors about the W206 C63 are in fact true. It looks like this electric turbo will be used on top of the 4-cylinder to fill torque gaps and get instantaneous power and response.
Full article here: https://www.motor1.com/news/429169/m...-turbocharger/
Mercedes-AMG Electric Exhaust Gas Turbocharger Eliminates Turbo Lag
Engine response will be instant.
It’s no secret that AMG has vowed to fully embrace electrification in the years to come as a follow-up to its super-rare SLS AMG Electric Drive launched back in 2013. The upcoming series of “73” models will all have plug-in hybrid powertrains with roughly 800 horsepower, while the AMG One with its F1-derived electrified powertrain will push out four-digit horsepower. It looks like the boys and girls from Affalterbach have another ace up their sleeves – an electric turbocharger.The newly developed electric exhaust gas turbocharger vows to eliminate the dreaded turbo lag. Engineered by AMG in collaboration with Garrett Motion, the new e-turbo is adapted from the exciting world of Formula 1 and combines the fast response of a small turbocharger with the high peak performance of a bigger turbo.
How is the turbo lag eliminated? By installing a tiny electric motor into the turbocharger shaft, specifically between the turbine wheel on the exhaust side and the compressor wheel on the fresh air side. Measuring approximately 1.6 inches (4 centimeters), the electric motor powers the compressor wheel before it starts accepting the exhaust gas flow.
Using this method, the delayed response of a conventional turbocharger is virtually eliminated, thus resulting in a more responsive engine right away and across the entire rpm range. AMG says the e-turbo also helps the ICE provide more torque at lower engine speeds, so the performance is significantly improved compared to a traditional turbocharged engine. Optimal airflow is guaranteed by the turbocharger as it can achieve impressive speeds of up to 170,000 rpm.
Mercedes-AMG doesn’t say which car will be the first to benefit from the cutting-edge technology, but we know from Garrett its e-turbo will be installed in a road-going vehicle as early as next year. Could it be the AMG GT 73? The Black Series? Time will tell, but we do know it will debut in a “next vehicle generation” as per the press release.
AMG boss Tobias Moers, who will become Aston Martin’s CEO on August 1, has already promised the Black Series will have “something different” in terms of engine, adding “we never did something like this with an engine before – for AMG it’s the first one.” It remains to be seen whether he was referring to the e-turbo or something else.
https://cdn.motor1.com/images/mgl/rP...rger.jpg//img]
It’s only logical that the successor to the current M177 4.0L will be based off the new M139 4 cylinder (as the M177 was based off the older M133 4 cylinder). It would be pretty insane to have a 4.0l V8 with a twin e-turbo system, as opposed to using electric power from the starter motor like most 48v systems.
Thing is these motors are already so responsive with small turbos in a hot v setup, I don’t really many opportunities for a 4.0l needing e-turbos to fill torque gaps... so maybe engine displacement and (sigh) cylinder count drops?
