ModalWorks Turbo Blanket product release
Pick up a cheap heat gun, go for a spirited drive, pop your hood and start aiming it around - you’ll be shocked how much hot air is dumping out of the top heat shield(s) past the compressor housings and into the engine bay. This keeps the heat retained inside, not only to lower under hood temps, but increase turbocharger response and efficiency by keeping the hot air contained within the turbine housing.
What I’m saying is from what I see, the blanket is not laying flat evenly which might create an uneven hot spot in the area. You want hot air contain and escape out not trap. Just like the factory design containing the hot air but also allow escape with the 2 vent
That's why we developed it and support ModalWorks efforts here also.
They work well, especially when filtration is close to the heat source like the W205.
Pop off the mostly decorative heat shield (you can literally just pull up on each side and it will pop out), and you’ll notice a second heat shield that does the actual work - it’s a simple thin layer of heat shielding that covers the turbines and downpipes/cats. It does nothing to contain the heat within the turbines themselves - it’s just a cover that lets 500+f air temps dump into your engine bay like a convection oven.
There’s a reason you almost always see drag racers and big turbos with blankets - these lava blankets actually work - you can put your hand on your turbine and it won’t burn you after a spirited drive. Try that without a turbo blanket (or even the factory heat shield below the decorative one) and you’ll have a reminder on your hand for the rest of your life 😆
Listen, I know how it work and Agreed 100% with you if it design to completely wrap around the turbo exhaust side. This is jus a blanket laying on top like a half *** job what it intend to do.
PTP’s 4.4l turbo blanket:
https://www.ptpturboblankets.com/pro...0i-650i-750i-1
Can you show otherwise? Please.
Some of the main driving decisions as to why we designed it the way we did are as follows:
1. The single blanket blocks more heat into the rest of the engine bay which lowers IATs
2. This product will fit larger turbine housings
3. It is cheaper to produce and sell, giving our customers a more affordable option than two separate blankets.
Hopefully this answers everyone's questions. Please feel free to DM or respond here if you would like to discuss more.
Here’s some food for thought, something that might get you thinking... I have a set of what appear to be prototype M17X turbochargers that have OEM heat wrap around the entire turbine housing to keep the heat retained inside the turbine housings. Our production units obviously don’t come this way, but AMG/Borg Warner were certainly up to something:
If you believe your own hype, why not offer insurance on your product that if there is engine damage, you will pay ALL costs to repair our vehicles, keeping in mind an engine for a C63S runs about $22,000.
Like the pic. Now that’s the right way if you’re going to wrap it. If oem start to do this, I don’t think it for power but just a better way To transfer the heat to keeping the engine bay temp down. There are many other way, the right way for the factory can do to gain more power rather just wrap turbo, DP ... etc.
I don't think that's asking too much here.
Remember the big stink here recently about Eurocharge and Ver.7(?) s/w upgrade? People complaining about the "either on or off gas pedal response".... We have a RIGHT to know what we're putting on our vehicles and any potential issues or problems that may come of that. Now, if we don't care for whatever reason and are willing to take that chance, then that's a different story. Unfortunately, I do care. So, I believe vendors and suppliers have an obligation to be forthright in their claims, graphs and charts. Enough have been called out over the years.
Also, the hot V already has a heat shield on the exhaust manifolds that blocks a ton of heat right back into the block, your concern with extra heat being trapped from the blanket and damaging the engine seems entirely unrealistic... how would that even happen? Let's consider a hypothetical situation where one moves the blanket on top of the heat shield that is already in place on the exhaust manifolds, would that make it any more dangerous for the block? All you would be doing is reducing more thermal radiation form the block upwards. The block is already red hot and designed for extreme temperatures.
These kinds of comments are the reason why everyone says mercedes has a crap aftermarket scene and tuners don't want to develop for them. IMHO the blanket seems like a simple and effective mod, if you don't like it, don't buy it. I'm all for doing due diligence but this seems pretty straight forward, it's not like the are porting nitrous into each cylinder and running 40lbs of boost.
In terms of cost/benefit, not many people are willing to go through that process and all that trouble (and cost) to ceramic coat turbine housings - at that price point you’d be better off throwing a blanket on. But no one is going to force you to do anything, you can always stay 100% stock since that’s how AMG intended and continue to assume that there’s no aftermarket parts that improve over OEM design, or concern yourself with potential issues installing any performance parts.
This is a pay to play game when it comes to modding, but for things a turbo blanket, or coating the turbo, it’s basic heat management mods that’s been done for years, decades even. If you’re that worried about it having detrimental effects, I wouldn’t consider modifying your car at all because a simple tune is putting WAY more stress on every single part of your drivetrain - from engine to the trans, driveshaft, diff and axles. A turbo blanket isn’t going to put additional stress on your turbochargers like a tune does by increasing duty cycle and increasing the boost over stock. It certainly will not warp heads and if you understood the heat shield manifold design, this would make sense to you.
