Turbo upgrade with original cat and downpipe
w205 c63s
Hello Guys
Is there anybody, who upgraded the turbos on c63s, without upgrade the downpipe and cats. I dont want to change the sound of oem performance exhaust system. Its perfect for me. No problem, if i lose some ponies.
Any experience?
Any experience?
same here... then don’t. Not a requirement when upgrading turbos. You could even opt for the Weistec stage 1 upgrade...they upgrade your OEM turbo and after it’s installed nobody could tell visually it’s different.
Without upgrading the exhaust or intake, upgraded turbos will be choked significantly. You will need to run lower boost than you would if you had those mods. You will also probably experience increased lag because an upgraded Turbo will have larger heavier wheels that take more time to spin up, and you do not have the offsetting benefit of having opened the intake and exhaust post turbo, to help spool time. And lastly the aftermarket turbos, which in all cases are less reliable than OEM turbos, is going to be under more stress because It won't be able to get air in-and-out as easily as it needs to for its flow requirements. Usually upgraded turbos without the supporting mods will leave you disappointed. I definitely think you will see a increase in power, but you will always be significantly lower than those who have the right supporting mods for a proper set up.
Do Pure Turbos stage 1 and intakes seem good for around 590 to 600 whp? I'm thinking to just skip the ECU tune only and just go upgraded turbos from stock without going too crazy.
Factory downpipes don't rob a consistent, static hp figure. It's a percent of what you would have optimally made with maximally-flowing exhaust. So if you gain ~30whp with dp's on a stock motor, could probably expect a significantly higher delta on upgraded turbos than what you would make with dp's. The bottleneck effect grows as you try to cram more through.
intakes absolutely as I said earlier but DP’s don’t think so. Look at Renntech and Weistec and they produce their largest turbo upgrades w/o DP changes. Yes, it sure will help but none include changing the DP as it’s technically not legal. They produce north of 800crank w/o it.
Look I hear you man, Having no cats can be smelly and expensive. Who wouldn't want to skip the down pipes if the factory ones would do the job. Sure, you can do it - I am not even saying that upgrading turbos without down pipes is "wrong"; just certainly not optimal. And that you should be realistic about expectations in that case.
So many opinions its hard to vet out the facts. But what about hi-flow cats in upgraded turbo applications? I've seen some comments about they have 95% of flow of catless pipes but I find that hard to believe.
https://www.renntechmercedes.com/ind...205-c63-detail
https://www.weistec.com/w-4-turbo-upgrade-m177.html
Both are compatible with stock DP's...and surprisingly both only want you to change the intake filter to a high flow filter, not even an aftermarket intake.
Now, you can add aftermarket intake and DP's and gain some more, but not required to upgrade the turbo's. I think most would tell you the first you should consider is the intake as they are more restrictive than the DP's once you have bigger turbo's.
I don't think its all that confusing. If you go bigger and dont want to change the sound of the engine as the OP wants to do, you don't need to changed DP's and can get 800-900 crank.
No idea how Weistec is going to make 950 horsepower without larger down pipes. I just flat out do not believe that claim, TBH. I'd love to see you try though.
So Renntech's dyno charts only show 610 WHP for R3 (which i think is a misrake in their site since their product page for the r2 pkg also shows 610 whp dyno) but lets say its actually 660 - which is 725 or so at the crank using modern trans loss of 10%. Far from 800-900.
I just gave round numbers for general idea and only Renntech and Weistec as examples. Renntech estimated 767crank in the table above the chart, close enough for me. Pure has tons of charts depending what else you do...and seems also in the range. In general, Renntech's packages are always most $/hp and usually also on the conservative side of what they claim.
My point in this thread is that engines are a system, FI motors are especially sensitive to intake and exhaust components having adequate flow to support power , and you cannot make the power if you can't get enough air in-and-out. If you don't have the proper supporting mods for the Turbo, you will not be able to fully realize the full power gains of the turbo. It is as simple as that .
I agree that you "can" leave the stock DP's and cats. When I look at Renntech site, I see they are getting 610rwhp with their turbo upgrade. I think the catch is they are using 20% loss calculations to get to their 760HP rating. Every tuner I've talked to says to expect 650rwhp to 670rwhp with turbo upgrade and catless DP's on 93 pump gas. So right there is a 40-60 rwhp gain by going with catless DP's.
Sorry but that sounds like you're moving the goal posts.
PS: Does not mean you don't get further improvements in performance if you do change DP's but again you can get very nice power upgrades w/o it if you don't want to change the DP's.
Also - The reality is that tuners inflate advertised numbers to sell turbos and packages. And you cannot just slap big turbos on an otherwise stock car and expect to achieve those numbers, or usually even close.
JPM-3 (07-20-2020)
I think it depends on the seller/tuner....Renntech are usually more conservative and in general I would trust them with their numbers. Their numbers often look underwhelming because of it (just compare the $23k R3 package they offer against competitors). Others might be off and in fact some even state those numbers depending on x, y, z to achieve (pure gives quite a lot of charts with different bolt-ons, race gas or standard but mostly provide what configuration was use, Weistec is more elusive)
Suggest calling some of these sellers/tuners and asking directly, what whp you can expect with just their turbo and tune ... see what they say.
Anyone using a 20% drivetrain loss on our cars is inflating numbers, and i wouldnt trust their claims unless some independently verifies it. Dont get me started on Renntech's cost:hp value, and I see nothing conservative in their claims. Turbo sellers across the board routinely tout the max-effort/full-build hp you can get with a turbo, i.e. the upper limit.
PS: Doubt Renntech overstates their whp...that what matters at the end.
PS - please try to follow, I never said whp claims are exagerrated. It is the crank hp claims that are often inflated by using drivetrain loss corrections that are too high. To cut through the BS, people should use wheel horsepower figures and compare those. Then do their own math using around 10% drive train loss as a rough guess to crank hp.
