C63/C63S AMG
new owner with few questions
Old Aug 17, 2020 | 10:55 AM
skratch77's Avatar
2005 E55
What oil are you guys using and what filter does this car take?
What is the widest tire we can run on the stock 20in rear wheels without the traction control freaking out and the car rubbing?
What drag radial setup are you guys running?
And does this car adapt to e85 mix without a specific tune for it?
Old Aug 17, 2020 | 12:09 PM
W205-S's Avatar
2018 C63S Coupe
I am currently running a PS4S 295/30/20 on the rear (stock AMG forged cross spoke 20in wheel) with no rubbing issues.
The 295 is made to fit a 10.5 wheel and fits flush IMHO (see pic below). The 285 stock tire just looked too stretched for my liking.
There are people on MB World running the 305/30/20 tire on the rear and say they have no rubbing issues.
I have personally seen this size tire on my stock wheel and I did not like the look of the slight bulge from the 305.
just my 2 cents!
Old Aug 17, 2020 | 12:11 PM
skratch77's Avatar
2005 E55
Originally Posted by W205-S
I am currently running a PS4S 295/30/20 on the rear (stock AMG forged cross spoke 20in wheel).
There are people on MB World running the 305/30/20 tire on the rear.
I have personally seen this on the on my stock wheel wheel and I did not like the look of the slight bulge from the 305.
just my 2 cents!
I hear you on the stretched look.. i will go 295s on next tire change.
Old Aug 17, 2020 | 05:16 PM
tobeit's Avatar
AMG C63s
just my 2 cents!
The "stretched" look is a bit visual and depends on brand of tire (design of sidewalls, shoulder, and actual tire width vs nominal). Michelin's PSS and P4S have that rim protective bulge and in general come in on the "narrow" range aka a 285 tire is technically 11.2" aka wider than the 10.5" rim yet looks a bit stretched due to the aforementioned details of the tire brand and design. 295 Michelins "look" more square on a 10.5" rim but in my case would likely rub a bit (or very, very close) on my sedan setup.
Old Aug 17, 2020 | 06:38 PM
deftronix's Avatar
17 C63S coupe
Just did my first oil change since buying the car with Liqui Moly Molygen 5w-40 - car runs great on it. Filter used is 176-180-08-00.
Old Aug 17, 2020 | 06:46 PM
skratch77's Avatar
2005 E55
Thats good to hear because i have a case of that oil that I used for my old c63.
Old Aug 18, 2020 | 07:49 AM
sinister.c63s's Avatar
2020 s63 amg............2018 e63s amg w213............2017 C63s Coupe W205
1. I use liqui moly 5w-40 in winter/spring and 10w-60 in summer/early fall. I always add a thing of ceratec when doing oil changes
2. You can run 305s, but 295 is really should be the widest
3. r888s or hoosiers will work at stock ride height
4. I try to never add more than 3 gallons of e85, but others may feel comfortable using more
